Home > Technical (L322) > Air Conditioning |
Pressure sounds low should be up in the 20's to 30's on the low side .
27th Jul 2018 8:17pm |
matlandy Member Since: 06 Aug 2016 Location: Crawley Posts: 134 |
Is that 20 or 30 Bar or psi |
27th Jul 2018 8:29pm |
Sorry, psi, so 10 bar....145psi !!
27th Jul 2018 9:11pm |
I found this piece of information but it still puts mine way off
27th Jul 2018 9:31pm |
2006Rangie Member Since: 26 Jan 2017 Location: Toronto and Melbourne Florida Posts: 20 |
The key information is the pressure on each side - low pressure and high pressure.
11th Aug 2018 6:07pm |
Looks like it might be the compressor. It goes in to the garage on Tuesday will let you know the outcome in case others get the same symptoms. |
12th Aug 2018 7:45pm |
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 439 |
Is the pressure the same with engine stopped and running ?
12th Aug 2018 11:45pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1688 |
This is correct With the system off/inactive, both high/low pressures should read around 5bar With the system working, the high pressure can read as high as 15bar, with the low side down between 1.5-2 bar |
13th Aug 2018 5:45am |
Turns out it is the compressor that needs replacing had a few quote. Might be winter by the time I save up lol |
21st Aug 2018 11:26am |
Check eBay, plenty of 2nd hand ones on there. .
21st Aug 2018 1:29pm |
Finally got it replaced nice and cold ready for winter |
3rd Oct 2018 1:22am |
3rd Oct 2018 12:21pm |
