Home > Wheels & Tyres > Range Rover sport 19 inch wheels on Td6 can you do it?
horsedentist
United Kingdom 2002 Range Rover Vogue Td6 Giverny Green
I have a set of 19inch RR sport wheels I want to put on my td6 I know you have to change to sport wheel nuts to put them on a L322. However I vaguely remember reading somewhere that you can only put them on a petrol L322. Does any one know about this ? What the problem is or if it is possible?
Post #484615 29th Jul 2018 2:12pm
wayneg
I have had 19" rims on mine from both L320 and L494. You only need the correct wheel nuts. I just buy set of wheels with good tyres then move them on when worn down but still legal. Keeps the cost of tyres to zero. The best combination for ride comfort, off-road use and cost is 265 60 18 but they don't look as good as 19`s or 20`s 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #484616 29th Jul 2018 2:27pm
SidewaysMatt
United Kingdom 2004 Range Rover Vogue Td6 Giverny Green
I think the issue you're referring to is that the TD6 was only ever available from new with 18" or 19" wheels, not 20".
Reason was that there is supposed to be a resonance problem at idle with the TD6 when fitted with 20". As I now have a set of 20" autobiography rims sitting ready to go on my TD6, will find out soon enough if it is a problem.
However, you should be fine with 19". 2004 Vogue TD6 - Remapped Smile
2008 Porsche Cayenne S
1998 Lotus Elise
Post #485963 13th Aug 2018 4:03pm
mjdronfield
TD6 only available with 18’s when new.
I put 19s on mine and didn’t have an issue. I don’t sit stationary in D anyway.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #485965 13th Aug 2018 4:46pm
mjdronfield
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #485967 13th Aug 2018 4:51pm
SidewaysMatt
Ah I stand corrected Thumbs Up Thought they were also supplied with 19" 2004 Vogue TD6 - Remapped Smile
1998 Lotus Elise
Post #485970 13th Aug 2018 5:11pm
Dolphinboy
United Kingdom 2011 Range Rover Vogue TDV8 Atacama Sand
I had these sport 19” on my 2002 TD6 and they were brill handling wise.
Post #486018 13th Aug 2018 11:02pm
bishbosh10
Just make sure whichever wheels you fit are load rated for your L322. Thumbs Up Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #486735 21st Aug 2018 12:57pm
Paul thornton
It's just the xl (extra load) rating you need but most 4x4 tyres have this anyway
Post #486767 21st Aug 2018 4:53pm
matlandy
United Kingdom 2004 Range Rover Vogue Td6 Java Black
This is mine with 19" RRS wheels on and GOODYEAR WRANGLER DURATRAC tyres fitted just had to change the wheel nuts.
Post #486789 21st Aug 2018 9:41pm
horsedentist
Cheers for all the comments guys. All on and they came with brand new perelli Zero tyres they seem to perform very well tyres could have done with being 55's rather than 50's throws the speedo out a bit but it was not accurate with the 18's on so now about 4mph adrift I can live with that until these tyres are worn out.
Post #487935 3rd Sep 2018 11:35pm
