Home > Technical (L322) > TD6 will not crank - immobilizer or other issue? |
Welcome to the forum
30th Jul 2018 8:37pm |
and after that I would check that the starter cable is properly connected, then check that the starter motor actually works (direct wiring from a battery, after disconnecting from car) .
30th Jul 2018 10:47pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
If it was immobilised you would have a fault code on the Allcomms from memory under the immobiliser section. The EWS immobiliser has to be synced with the engine ECU. Allcomms can read the fault but can’t program the link.
30th Jul 2018 11:49pm |
PIMCO Member Since: 30 Jul 2018 Location: Oslo Posts: 44 |
Thanks for the warm welcome and suggestions!
31st Jul 2018 11:15am |
I got the following six codes:
31st Jul 2018 6:06pm |
Transfer Box Module: “Battery undervoltage (0x5212)”
31st Jul 2018 8:55pm |
As I was suspecting a battery drain since I got the car, (attempting to) measure the current draw was one of the first things I did. Of course, not knowing the shutdown period and such I was not able to get any practical readings.
1st Aug 2018 11:43am |
Any more suggestions or people that have had similar issues? How do I go about diagnosing the immobilizer ECU itself? |
21st Aug 2018 7:29am |
Going back to the beginning, can you lock and unlock it with the alarm fob?
21st Aug 2018 7:58am |
alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349 |
One thing that has happened to me recently, I was getting the same and threw me completely, there was no clicking .I directly linked the starter, crossing the feed to the solenoid . It was the solenoid that had broken down and so I bought a s/h starter and refurbished it taking it apart and rebuilding , jobs a good one.
21st Aug 2018 2:50pm |
Alfapat nailed it! I shorted the prongs on the solenoid with a screwdriver and the car fired up. Never had I imagined that the culprit would be a component this simple.
30th Aug 2018 10:20am |
I bought a complete unit , stripped both down and cleaned all components lightly lubricating moving parts but not in motor.It was mostly carbon holding up the solenoid , but turns twice as fast now and sounds like new.I ran a bench test first and could see what was happening , just take pics to confirm your rebuild , I still have some parts of the old motor, thats your best way of solving it , my only issue was snapping a stud in the starter carcase as they were extremely tight, good access I discovered after bending over engine to get the bolts off the engine block for four hours, was to take the main middle part off the bulkhead LOL and thought why did I not do that earlier! |
30th Aug 2018 10:49am |
Did you buy a used unit? So the solenoid casing was just filled with gunk/debris? Did you find that you needed the extra starter/solenoid, or could the original one suffice if you cleaned it up?
9th Sep 2018 4:21pm |
It was s/h from a scrap yard £35 . If you remember I broke or snapped a stud in it so getting a starter body was the first thing and from then cleaned up , there was a good deal crud /dust etc and I made it all up again . Worked a treat , you don’t need to spend as much as you suggest. From the description given at the beginning of the thread it was just needing a strip down , hope that helps. |
9th Sep 2018 6:41pm |
