Home > Technical (L322) > Can I get to the exhaust manifold through the wing?
GGDR
Hi guys, I'm being lazy on a rainy evening..
With the front wheel off - and the inner wing liner out, what's the side engine access like?
I need to get to the NS exhaust manifold. Top access is a PITA due to the sheer volume of components on these things.
Cheers for any wisdom.
Greg Cheers, Greg
Post #485580 9th Aug 2018 9:44pm
GGDR
Courtesy of Salter121:
He's posted a bunch of pics of his engine-less 2011.
http://www.fullfatrr.com/forum/topic47799.html
. Cheers, Greg
Post #485587 9th Aug 2018 10:25pm
John w
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
I don't think you can get to it,the strut tower and chassis rail gets in the way. Too many toys, not enough time
2011 4.4 TDV8 AB Black
Post #485606 10th Aug 2018 9:11am
John w
From his thread:
http://www.fullfatrr.com/gallery/albums/us...G_1414.jpg
Not much gained by removing the arch liner, still too much in the way. Too many toys, not enough time
Post #485608 10th Aug 2018 9:17am
GGDR
Thanks John. I'll get the wheel off anyway just to do a recc'y.
BTW emailed you.
. Cheers, Greg
Post #485610 10th Aug 2018 9:28am
Baltic Blue
Greg,
It is very easy to remove the air filter box and pipe, which may allow you to see how big a job it is before the point of no return.
Post #485631 10th Aug 2018 1:38pm
