Home > Technical (L322) > Suspension inactive
rik
Scotland 2003 Range Rover Vogue 4.4 V8 Bonatti Grey
Suspension inactive
Had the suspension inactive a couple of times over last few months .Could not find the culprit until today .My pump is in right hand side well and on poking about with it there was a hiss .One of the plastic pipes coming from pump had been rubbing and has 2 holes in it .Anybody know where I can get new pipe?
Post #485709 11th Aug 2018 2:04pm
rik
Pic of offending pipe. Can this be repaired. Or is it new pipe and anybody know how they are attached look shrunk on
Post #485727 11th Aug 2018 5:57pm
No "pic" Thumbs Up .
Post #485732 11th Aug 2018 6:13pm
rik
Post #485733 11th Aug 2018 6:32pm
rik
Post #485734 11th Aug 2018 6:33pm
rik
Small piece I cut out of loop with hole in it
Post #485736 11th Aug 2018 6:45pm
rik
Ok tracked down 6mm repair kit with push fittings and a length of pipe £9 free postage fingers crossed
Post #485743 11th Aug 2018 8:03pm
Sounds like a plan Thumbs Up .
Post #485748 11th Aug 2018 8:31pm
rik
Hope it works
Post #485749 11th Aug 2018 8:35pm
lounge_on_wheels
Australia 2003 Range Rover HSE Td6 Zambezi Silver
Land Rover actually have a repair kit for P38s , which use a 6mm air hose, probably would work on the L322 also if the pipe is 6mm diameter, part is STC8590 .
Post #485914 13th Aug 2018 11:25am
rik
Thanks for that .yes got a couple and a length of pipe 6mm push fit from ebay £9 free delivery .Just bought car soft diagnostic tool looks good .Local garage told me pipe can not be repair hope he is wrong ,
Post #485968 13th Aug 2018 4:53pm
rik
Works a treat easy fit and still going strong good fix 👍
Post #486340 17th Aug 2018 7:36am
