Home > Technical (L322) > Haunted Steering Column! |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 666 |
Unfortunately, that's not an uncommon fault !
11th Aug 2018 10:47pm |
See here
12th Aug 2018 12:47am |
phn Member Since: 10 Aug 2018 Location: Norwich Posts: 27 |
Hi Pawl, do you happen to know which the relevant fuse is, and where I could find this - would be an easy short term fix!
12th Aug 2018 7:29am |
I'm not sure which fuse is involved.
12th Aug 2018 9:11am |
I've decided to try the IID tool fix as I wanted to get one of these anyway!
13th Aug 2018 4:58pm |
While doing something else to the car today, I coupled up the IID tool & was surprised to see the easy access tilt & reach options were OFF - so not sure why it's still necessary to disconnect the tilt motor to prevent it motoring up & down when inserting / removing the ignition key. Paul,
13th Aug 2018 6:21pm |
The IID tool was a success!
18th Aug 2018 8:23pm |
