Home > Wheels & Tyres > Tyre Question for Sport Wheels going on to an L322 please |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 |
Either 255 50 20 or 275 45 20 should be fine I would have thought.
12th Aug 2018 2:05am |
green-oval-nut Member Since: 02 Sep 2016 Location: Tunbridge Wells, Kent Posts: 920 |
Thanks. I was worried about the 255 and 275 width difference causing any issues as I don't know what J the standard L322 wheels are and what J the sport wheels are. |
12th Aug 2018 2:08am |
I have 275 45's on my 7 spoke 20's. I think the sport wheels have a lower offset which puts them further out towards the arches which isn't a bad thing. |
12th Aug 2018 2:12am |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 |
RRS have a lower load rating, so check this also.
12th Aug 2018 9:15am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7629 |
The 20” sport alloys are wider, by an inch, 9.5J against 8.5J and the general thoughts are that its a bit more of a stretch for 255 tyres....that’s the question you need an answer to. Hence 275 being used. If it were me, I’d stick with 275 and get the tyre profile that best matches the overall diameter of the standard 255’s. I’m no expert though. 2011 Range Rover Vogue SE 4.4 TDV8
12th Aug 2018 2:05pm |
Looks like 275/45/20 if you want that width then. 2011 Range Rover Vogue SE 4.4 TDV8
12th Aug 2018 2:08pm |
gettingold Member Since: 03 Apr 2018 Location: Wiltshire Posts: 284 |
As above i would not put 255 on anything above 8.5j. Our RRS1 has 9.5 with 275/40s' on but the winter wheels are 8.5J with 255. As you I looked but it was a no no fitting the small width on a wider wheel.
13th Aug 2018 9:29am |
Cheers for the advice, exactly what I was trying to find out, as I have no idea when it comes to tyres. I now plan to fit 275/50/R20 Tyres to the alloys. And yes they have the Land Rover logo's inside all of them so luckily they are genuine. Just need to get them refurbished. I was hoping though the wheels were the same width as the originals so I could spend a little less on the tyres as tyres at the size I clearly need are a lot higher than the standard 255 tyres. |
13th Aug 2018 7:29pm |
Have a look at this for your tyres, as it may throw out your speedo. At least you'll know by how much.
14th Aug 2018 9:41am |
275 50 20 will have a taller sidewall than a 255 50 20.
14th Aug 2018 3:31pm |
grey17 Member Since: 31 Aug 2018 Location: ha6 Posts: 65 |
The RR Sport has 9J 19" wheels using a tyre size of 255/50 r19 or, 255/55 r19.
31st Aug 2018 6:50pm |
horsedentist Member Since: 23 Jun 2017 Location: london Posts: 158 |
I have just put a set of sport 19's on my L322 they have perelli zero 255/50/r19 tyres on they have a slightly different offset I believe it is only a couple of mm. They perform fine but you need to buy the sport wheel nuts for them as the holes in the rim are considerably bigger than the L322 rim.
3rd Sep 2018 11:21pm |
Hi Horsedentist.
4th Sep 2018 12:22pm |
