Home > In Car Electronics (L322) > Nextbase Dashcam - Hardwire Installation |
iani Member Since: 27 Oct 2012 Location: Corby UK Posts: 37 |
I'm trying to fit a Nextbase hardwire kit, I've run the cable under the headlining and down the windscreen side airbag cover, I'm following the process as shown here: http://www.fullfatrr.com/forum/topic23389....g+dash+cam
12th Aug 2018 3:50pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3193 |
I have just fitted same today- Nextbase 412. My airbag switch is on the panel on the side of the fascia. I removed it to get to the side of the fusebox. It was only a question of disconnecting the plug once the panel was free.
12th Aug 2018 4:09pm |
I drilled the frame that the side panel plugs into and used a small nut and bolt. I have used a self tapper on a previous ff John
12th Aug 2018 5:20pm |
Thanks, sorted now, I earthed it to one of the screws holding the glovebox on, works fine. I was being too gentle with the side panel, it came off fine with a good tug.
12th Aug 2018 5:33pm |
Pvw10 Member Since: 04 Nov 2015 Location: Ledbury Posts: 314 |
All the power you need is in the sunroof switch area, I wired and fused mine in there, much easier and tidier. Many thanks
12th Aug 2018 6:05pm |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 385 |
Pvw10 - That sounds interesting. Any more information?
13th Aug 2018 10:30am |
I bought one of those little 12 to 5v converters added an inline fuse and snatched into the sunroof power as ignition controlled.
13th Aug 2018 10:57am |
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 785 |
Is this what you used / https://www.ebay.co.uk/itm/DC-DC-Step-Down...SwNmNakk7W |
20th Aug 2018 12:37am |
Yes or very similar, I ordered from China and bought for about £1.50 each so bought 5 so could do other vehicles.
20th Aug 2018 10:03am |
Did you bury it behind the front interior lights consul and if so, how did you remove the big plastic cover with the lights and sunroof switches in ? |
20th Aug 2018 10:17am |
I removed the smaller piece, the little vented panel from memory by the roof switch, plus dropped the actual rocker switch out. Then you can do it all externally then push all the bits back in through said panel.
20th Aug 2018 10:27am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34915 |
heres an ebay UK one for £2.89 and quicker delivery but with an usb socket...
20th Aug 2018 10:50am |
Cheers for that. |
20th Aug 2018 10:53am |
