Home > Technical (L322) > burning smell |
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 439 |
Can you narriw it diwn a but, What sort of burning smell ?
15th Aug 2018 10:26pm |
Harlin Member Since: 06 Jul 2016 Location: ,essex Posts: 157 |
more like a clutch but not like a slipping clutch |
15th Aug 2018 11:09pm |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 695 |
Brakes binding? |
16th Aug 2018 7:20am |
not brakes |
16th Aug 2018 8:28pm |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2598 |
Alternator smells a bit burny when it's on it's way out! |
17th Aug 2018 10:42am |
Spooky Member Since: 03 Aug 2009 Location: Swindon, Wilts Posts: 183 |
Supercharger drive belt?? Regards,
17th Aug 2018 6:06pm |
Unless you have a very rare fattie indeed there is no clutch as it’s automatic.
18th Aug 2018 10:02am |
I would be inclined to go for a drive to get it to happen, stick it on max height, and have a crawl and sniff, see if you can narrow it down that way to at least a general location.
18th Aug 2018 11:42am |
its a 06 , 4.2 sc its not just the smell i also lose power with a clater sort of noise which is much worse if i put it into sport mode ,could it be the cat . i am not sure if the cat would smell when i put my foot down but the sound seems to be from that area , cheers rob |
22nd Aug 2018 6:34pm |
Since it is Supercharged I would therefore suggest you have a good look at the drive belt.
22nd Aug 2018 9:45pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
Clattery noise , lack of power and burning smell are not good combinations but I would expect some codes if transmission related.
22nd Aug 2018 10:05pm |
m@ttsFF Member Since: 12 Dec 2017 Location: Surrey Posts: 326 |
Suggest you Get it to a garage for accurate diagnosis before it becomes undriveable ... it ain’t going to improve 4.4 AdBlu Tractor
22nd Aug 2018 10:17pm |
no codes on transmission so hoping its the cat (cheapest option) |
23rd Aug 2018 4:34pm |
its the cat |
7th Sep 2018 5:40pm |
