Home > Technical (L322) > Fault code help need some brains
Henda
United Kingdom 2006 Range Rover Vogue TDV8 Zambezi Silver
Hello I sometimes get the eml symbol no loss of performance when I check the faults the same 4 appear
Your help is needed
Here goes
1 h/vac -heat/cool 0x30 air quality sensor line fault
2 instrument pack u-0400-68(26invalid data received (event trouble code)
3 engine p0102-21(28. ) mass volume air flow circuit low
P007f-62(68charge air cooler sensor bank 1&2 correlation
P-140-21(28. ) exhaust gas recirculating sensor c -low circuit
P02ao-00(68 ), po2bo-00(68 , po2b4 -00(68, po2ac-00(68 balance injector restricted
4 tmc traffic messages b1a56-18(2b) antenna circuit
Cheers in advance
Done some live values on the injectors
Tick over and reving at 1600 rpm and they all read 983 and at tick over barring 1,4 & 6 which are around 1045 at tickover
Once the faults are cleared the eml goes out and only running at 13.6 volts running
Don't know what happened there but all the smileys are 8
Now you see why I need brains
Cheers again
Post #486402 17th Aug 2018 6:34pm
Henda
Think it's reads sense now Thumbs Up
Post #486410 17th Aug 2018 8:02pm
