![]() | Home > Technical (L322) > Auto Wipers |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1762 ![]() ![]() ![]() |
Thought I'd start a new thread rather than continue hijacking others.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801 ![]() ![]() |
auto wipers need to be reset on each startup, well mine do...did you do this ? ... - .- -.
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6376 ![]() ![]() ![]() |
Indeed, they are not the best auto wipers and mine don't vary with speed or stop when I do. My RRS did that though.
Dogman Member Since: 10 Dec 2010 Location: UK Posts: 174 ![]() ![]() ![]() |
This all sounds strange as I have never changed mine (except occasionally moving the stalk to initiate a manual wipe) so maybe when Gaz gets back from pc world he can let us into the secret of setting up the auto wipe as it's as he left it on mine. |
OK - How do you "reset" them. The manual says move the stalk to position 1 (which is technically intermittent setting).. It says you can vary the setting using the twist switch (or intermittent wipe delay) which I did. But nothing Auto about it still.
Nickj Member Since: 13 Aug 2010 Location: Ipswich Posts: 262 ![]() ![]() |
When it says reset it just means move them up and down on the stalk, so yes, to ittermitant and back. If this is not done on start up they won't do anything regardless of amount of rain. I think i read somewhere this is a safety fuction maybe due to american market and people going through car washes and getting the wipers mangled!! I may of made that up though!
Somebody answer his question, fer chrissakes! ![]() here's what your mirror would look like w/o a sensor and here with ![]() and here from outside the car
Resetting is done via diagnostic interface - so no easy out there. I've always found them to work quite well in BMW's, RR's (same system). ![]() RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
Thanks Steve,
You will definately have them, you can confirm this on the build list for your car in Microcat.
OK but mine is the mirror as pointed out by Steve with the red bulb underneath, not with any sort of sensors behind it other than dipping lens.
I have them and I have the red pod underneith... This is the alarm beacon & IR alarm receiver (for markets where RF is not allowed)
Yup, I wasn't talking about the bulb - that's for the alarm as Dan says. The cover for the mirror mounting arm is the giveaway -skinny w/o and fat with a rain sensor. And from the outside the purple square as in the last pic. Thats the rain sensor. It shoots IR light into the glass which is reflected back and forth between the 2 glass surfaces w/o disturbance in the dry. When there is a drop of water on the glass it actually 'seeps' the light out of the glass and less reaches the IR receptor.
RRCanuck Member Since: 23 Dec 2009 Location: Ontario Posts: 172 ![]() ![]() ![]() |
mine too ![]() mike |
OK - Slightly delayed.
