Home > Technical (L322) > New noise in park, neutral only plus one more question!! |
Darryl72 Member Since: 25 Oct 2016 Location: East Sussex Posts: 62 |
Just another thought..is it possible a dodgy starter motor would effect the ignition sequence? Likely the starter motor has died....sorry I'm lost so any assistance would be great. |
3rd Sep 2018 6:45pm |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
Where was the smoke from ?? 2015 4.4 AB
3rd Sep 2018 6:58pm |
I'm not sure it was coming up when lifted the bonnet.around the rear of the block is all I can narrow it down. Possibly starter motor....is that possible? |
3rd Sep 2018 8:21pm |
Im far from an expert but smoke could be a burnt cable more thannthe starter motor. Hopefully one of the experts on here will chime in shortly. 2015 4.4 AB
3rd Sep 2018 8:32pm |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 509 |
What voltage is the battery reading? 2016 Skoda Octavia VRS Estate
3rd Sep 2018 8:50pm |
Don't know I can check tomorrow afternoon, what are you thinking Mike? |
3rd Sep 2018 8:59pm |
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 439 |
It sounds to me like your starter motor has possibly got stuck engaged, and has burnt itself out, or the contacts on the solenoid.
3rd Sep 2018 9:43pm |
I was wondering if it could be your alternator. They have a habit on Discos of burning out and taking the battery with them when they go.
3rd Sep 2018 9:51pm |
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 218 |
Ignition switch gone faulty causing starter to be engaged maybe ? New switch and starter needed maybe ? |
3rd Sep 2018 11:18pm |
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 |
A year and model of car would be helpful. |
4th Sep 2018 2:14pm |
Right thanks everyone I have something to work with, at the weekend my first thing will be to remove and test the starter motor (just wishing my arms were another two foot longer...looks a pig)
4th Sep 2018 5:15pm |
Cheap and easy to charge the battery - should really be over 12V, ideally 12.3V+ with engine off and car asleep. See if charging it makes any difference.
4th Sep 2018 9:46pm |
8th Sep 2018 8:27am |
8th Sep 2018 6:44pm |
