Home > Maintenance & Mods (L322) > Black smoke ( photos ) |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7738 |
Replace the other side at the same time - it won’t be too far behind |
6th Sep 2018 6:19pm |
Henda Member Since: 02 Aug 2018 Location: Gateshead Posts: 282 |
Cheers mate ordered two silicone replacements just because they look nice |
6th Sep 2018 7:31pm |
SinbadRose Member Since: 21 Aug 2017 Location: Merseyside Posts: 114 |
I don't get smoke or anything, but was thinking of doing the pipe replacement as a "best before it does go" type of job, reading some of the other threads about how some think things like this can cause issues later if they do split, i think i shall do mine when it stops raining. |
6th Sep 2018 8:48pm |
http://www.fullfatrr.com/forum/topic26843.html
6th Sep 2018 8:55pm |
I wouldn't dream of driving my 3.6 v8 beast fast or hard it just wouldn't be right
6th Sep 2018 9:02pm |
Videoman1959 Member Since: 11 Apr 2015 Location: United Kingdom Posts: 77 |
I had the exact same problem as you with the black smoke. I changed the two BIG pipes under the bonnet and the black smoke went away .
10th Sep 2018 8:24pm |
Injector cleaner is a tip it in a full tank of fuel job. EGR cleaner not so much. There is nothing that can't be fixed with a hammer😜😜
10th Sep 2018 10:57pm |
Any particular cleaner recommended for a L322 TD8? And regarding the Wynns EGR cleaner, do I squirt it into the ( as I look at the bonnet from the front of the car) right hand air pipe or left hand one please?
11th Sep 2018 7:24am |
If you're using the spray type you can either take the air filter cover off and spray from there or the two intake pipes off at the same place and spray alternately in short bursts
11th Sep 2018 8:44am |
