Home > eBay & Bargain Spots > Wow this must a very rare car.. 1972 4 door RRC ! |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Was smurfing and saw this.....
7th Sep 2018 2:29pm |
If its real then restored could be collectors item. |
7th Sep 2018 3:33pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1691 |
It looks like a late car, and has alloys fitted
7th Sep 2018 5:04pm |
Montverdi, I believe? |
7th Sep 2018 5:05pm |
Jamiehol Member Since: 26 Sep 2014 Location: Ipswich Posts: 220 |
I guess someone has put a late shell on an early chassis and VIN probably to get free road tax at some point. |
7th Sep 2018 6:42pm |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1619 |
in 2006 it had only had 8K on the clock and 2 years later still not broke 11k.
7th Sep 2018 7:58pm |
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 439 |
Now that's a project for someone.
7th Sep 2018 8:14pm |
Boxbrownie Member Since: 19 May 2018 Location: FF gone now....FL2 i6 to play with Posts: 245 |
Solid underneath.........not withstanding the hole which the brambles are growing through! David
7th Sep 2018 8:17pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2304 |
I think he's confused about the year - perhaps someone told him that these were made from around 1972. Sept 84 build lost the front quarter windows but the centre console doesn't appear to have ashtrays like my Sept 84. He doesn't say that he has owned it from new, just ...forever, meaning that it feels like for a very long time. |
7th Sep 2018 10:17pm |
nearlee Member Since: 28 Feb 2018 Location: Where the sheep are scared Posts: 245 |
Something very wrong, possible 're shell onto a 72 chassis engine and axles.
7th Sep 2018 10:40pm |
The door handles are in the LR production location rather than the Montiverdi location which was an inch or so higher and always sticks out like a sore thumb... |
7th Sep 2018 10:44pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7629 |
Yeah....and the shut line angle is wrong between the bottom of the rear window and the rear wheel arch, plus the small window in the rear door is wrong for a Monteverdi too. It’s def a factory shell.
7th Sep 2018 11:38pm |
I think it's an early 4 door full stop. 1981 to 1986 as it has the exposed hinges on the bonnet and doors... As far as the reshell goes there are a few wee problems with that... the original RRC that used the lt95 box (4 speed and transfer in same case) had a fixed cross member.. meaning that to do a clutch you either had to strip the interior out and remove the floor, or, you had to remove the engine.. Now I could be wrong, but I don't think that the 5 speed gearbox with fit in the early chassis, and to get at the gearbox for any work it will be body off.
8th Sep 2018 1:47am |
19sjw Member Since: 18 Oct 2014 Location: East Anglia Posts: 25 |
Surely the early 2 doors came out early 70s,on a H/J plate,so this cant be the correct number,it being a dateless one which finished early 60s? |
8th Sep 2018 8:00am |
