Home > Maintenance & Mods (L322) > Front and rear diff oil change
jaysta10k
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Hi guys my TD6 is on 150000 just wondering if an oil change in both diffs is needed at this milage?
Cheers Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
Audi A4 2.7 TDI S Line Black Edition phantomn black
Previous Cars
Range Rover Vogue SE Overfinch Styling 22" Elara's full black stealth colour coded
Java black Range Rover sport 2.7 TDV6
Alaska white Range Rover sport overfinch 3.6 TDV8
BMW M3 Carbon Black
Post #488664 11th Sep 2018 12:24pm
It certainly can't hurt, if it has not been changed before it will black and 'orrible!
Use the correct specified fluids and make sure that the fill plugs will undo before you drain the diffs. .
Post #488667 11th Sep 2018 12:42pm
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
Just stumbled on this post gents, Joe would it be better to drain the diff oils once its been driven for a while and warmed up, to get more of the cr@ppy old stuff out?
Post #490485 30th Sep 2018 11:44pm
Absolutely it would be better to warm the diffs first sir Thumbs Up
Post #490487 1st Oct 2018 12:01am
mrblonde
Thanks Craig, thought it was the case but wanted to double check first (damn OCD)
Post #490492 1st Oct 2018 2:28am
EmiratesA380
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Aintree Green
Re: Front and rear diff oil change
Cheers
When you consider that the Front Diff only holds: -
Fill the front differential case with the correct amount of fluid.
If the differential has been replaced, fill with 800 ml (1.7
US pints) of fluid.
If the differential has been drained but not replaced, add
750 ml (1.6 US pints) of fluid.
and the Rear Diff only holds: -
Rear Drive Axle/Differential -
Open differential 1.14 liters (2.41 US pints) (1.20 US quarts)
ETM differential 1.55 liters (3.28 US pints) (1.64 US quarts)
********** * Recommended lubricant: *************
Open unit Castrol SAF-XO - 75W/90
ETM unit Castrol SAF Carbon Mod Plus
THAT OIL HAS A VERY HARD LIFE - 150,000 miles is far too long - Its such a easy job to change and 20,000 miles is a good service life !
Time to change around 15mins per Diff !
and will only cost around £20 per Diff
Peace of mind with new oil !
Post #490645 2nd Oct 2018 10:09am
mrblonde
Thanks again for the info Emirates, will get into routine of changing the oils more regularly
Am just getting over an extra £500 spend last night on 2 new front air struts and other bits, so feeling almost as deflated as my poor old front shocks today.... Big Cry Big Cry Big Cry
Post #490656 2nd Oct 2018 12:35pm
Me blonde, might I suggest you go out and liberally spray the bolts through the hub & shocker with penitrating fluid so they get as long as possible to soak before the job is undertaken sir... I would do it 6 hourly if it were mine 👍
Post #490658 2nd Oct 2018 12:42pm
mrblonde
Thanks craig, thought that as she is 15 years old and never been touched before Embarassed
Will WD40 be ok? Or plus gas from work? Was going to soak every part I can get to at the moment, and the rest once she’s trailered home
Post #490667 2nd Oct 2018 1:26pm
EmiratesA380
mrblonde
We are all here to help fellow FF users Thumbs Up
WORTH MENTIONING:
When you get the old ones out - FIT NEW LR Drain & Fill plugs - never use the old ones ( A piece of mind )
and Don't forget never Torque up bolts/plugs when the casings hot - let it go cold ( metal expands when hot - you need to tight fit and at the correct Torque value as recommended by what you are working on.
I tend to keep 20 of everything in stock at home - especially oil filters / drain plugs and brake nipples
Good luck
Post #490711 2nd Oct 2018 5:54pm
mrblonde
Thanks again mate, you seem way more organised than me with spares etc
Can I check a couple of part numbers with you, been trawling the russian parts catalogue and still struggling with diff and transfer box plug numbers, I have:
Transfer box - Fill & drain plugs TYB500110
Front Diff Fill plug TYB000010
Front Diff Drain plug TYP000220
Rear Diff Fill plug ?
Rear Diff Drain plug TGZ000030
No worries if not, but thought you may have them to hand
Post #490757 3rd Oct 2018 12:31am
EmiratesA380
mrblonde
I am somewhat confused ! - is your vehicle and you in Russia ?
Perhaps its worth posting a picture of your FF in Mongolia - its one massive country and well worth the drive if you are in Russia !
I suggest you only purchase genuine OE from Jaguar Landrover - parts are available Worldwide:
https://www.landrover.com/ownership/contact-us/index.html
Fitting third party kit not worth the risk - They were built at Solihull with British Parts !
Post #490776 3rd Oct 2018 8:36am
mrblonde
Sorry Emirates, bit of confusion. I use the russian parts catalogue as its favourited on my computer (someone on here shared a link to it, and its easiest for me to navigate, even without my cossack hat on Embarassed )
I live in Hertfordshire so nowhere near the former soviet block, and the only brown bears I have to face are the plush ones our dog rips the stuffing out of Mr. Green
All sorted now for the numbers, and ordered from a well known online supplier. Cheers again for your help! Bow down
Post #490798 3rd Oct 2018 12:55pm
mrblonde
Quick update all, change both diffs and transfer box oil last week finally, and just a warning to anyone whos doing it - The stuff absolutely stinks! So much so, I'd left the drain pan beside the front door to go and get a funnel and empty containers to dispose of it correctly, and when I came back, the mrs had called the gas emergency line as she thought the smell was a gas leak Embarassed Embarassed Embarassed Embarassed
Post #540711 15th Jan 2020 9:17pm
RichM63
France 2006 Range Rover Vogue TDV8 Stornoway Grey
By heck Exclamation 1 1/4 years taken to change the diff oils.
No wonder your missus thought that there had been a 'gas leak'. Shocked
Post #540713 15th Jan 2020 9:32pm
