![]() | Home > Maintenance & Mods (L322) > Fitting towbar to a design pack FF |
Not at all... The under tray has a line to cut to for it to fit around the tow bar... So very easy sir |
mm289 Member Since: 11 Mar 2016 Location: Hampshire Posts: 207 ![]() ![]() ![]() |
Cool, thanks CTC, so basically just same process as on my 06 but relieve the undertray to the cut out markings?
Yep thats correct sir... They even have a recess built into the bumper where the factory electrics appear as if you fitted them that way! (all will be come clear if you look at a bumper fitted) |
Cheers bud |
Scottyav Member Since: 11 Feb 2013 Location: Cannock Staffordshire Posts: 1204 ![]() ![]() ![]() |
Mine had one on before Craig took it off |
Great thanks |
Went straight of on hols after picking the car up so just had my first chance to look at the towbar.
Any suggestions? |
