I would imagine as a 2010 it’s probably a 3.6.
As said get round the car without the bloke there and have a good look. Browse the wiki at the top of the site page for the common problems and buyers guide.
As a stop gap car while you look for your 405 it’s probably not going to be with you for long so if it doesn’t drop to bits there and then you are probably ok!!
EGRs are difficult to check, as is the state of the turbos, but if the maintenance is there then they could well be problem free. Check the top turbo hoses, and on a test drive make sure you give it a couple of boot fulls of go pedal. If possible get a friend to follow you on the sets and keep an eye out for clouds of black smoke.
As a 2010, be aware that the NAV latest update is 2014 and that costs £££ to get so get a Tom Tom, and buy a tune2air/bovee for wireless music streaming.
Look out for errors with the adaptive suspension, this is caused by a couple of broken wires and is an easy fix, and the rear dampers do weep slightly so that’s ok (it’s not, but they pretty much all do that). There is nothing that can't be fixed with a hammer😜😜
