Home > Technical (L322) > 2007 TDV8 complete electrical failure |
Harlequin Member Since: 26 Sep 2018 Location: Crowborough Posts: 57 |
Hi all
1st Oct 2018 12:05pm |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1097 |
I'm by no means an expert on this model or year, perhaps search here for ignition barrel failure........ Current: 2011 FFRR Vogue SE 4.4 TDV8
1st Oct 2018 1:14pm |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 697 |
My money would be on the ignition barrel, I’ve changed one myself and know of others from 07 that have needed it. It isn’t ruinously expensive and isn’t too hard to change. |
1st Oct 2018 3:52pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8479 |
+1 for the barrel. There is nothing that can't be fixed with a hammer😜😜
1st Oct 2018 8:34pm |
Thanks guys really appreciate you taking time out to help. |
1st Oct 2018 8:39pm |
So, the garage is still working it out, so i have asked for and will receive a refund for the car!
5th Oct 2018 7:29am |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 |
Your call on a refund but if it is the ignition switch it's a known fault and when fixed its sorted. Another of similar age may well be the same 6 months down the line and then you will be picking up the tab.
5th Oct 2018 8:53pm |
Thanks Grofus, all covered by warranty so should be ok. Appreciate the thought though, thank you
5th Oct 2018 9:43pm |
