Home > Technical (L322) > Rear ventilation button
dolph34
Hi all, on my 2011 VSE the button that allows the rear heating controls to work comes on every time i start the car. On my 2007 VSE was the other way. I would prefer it worked the 2007 way. I have checked the owners handbook and the IID TOOL, can anyone help. First world problem i know Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #490578 1st Oct 2018 7:24pm
default seems to be 'on' whether you switch it off or not..
does it really bug you that much..
Post #490601 1st Oct 2018 9:19pm
mjdronfield
It sort of bugs me too. I can count on one hand the number of times peeps have travelled in the back of my car, so I’d like to know what it’s doing...is it just heat? If I have AC on full cold I assume rear will blow same, irrespective of button? 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #490602 1st Oct 2018 9:31pm
dolph34
It does bug me but when my 2007 was the other way i hoped there was an easy fix , something like holding it in for 5 seconds or the like.
Im a single dad so i have my daughters in the back every day for the school run but its a small niggle and as i said i do appreciate its a first world problem. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #490603 1st Oct 2018 9:46pm
John w
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
I found on mine (2011 spec, 4 zone a/c) that if I set the fan speed from the rear seat control to minimum, it doesn't come on.
If however I press auto it uses the rear vents too in order to heat the car up quicker.
On a different note, my aircon button has two leds on it, which I cant figure out what they are trying to tell me. Only once has it had both leds on at the same time. Too many toys, not enough time
2011 4.4 TDV8 AB Black
Post #490661 2nd Oct 2018 12:53pm
mjdronfield
Which one on here? It’s either for auto fan or auto air distribution on knob 7, or auto/always on/always off air recirculation on button 1.....I would imagine.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #490666 2nd Oct 2018 1:22pm
dolph34
Hi , if the diagram is for me , its not on that picture, the switch is under button 1 on the diagram/ picture. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #490699 2nd Oct 2018 5:17pm
this,
Post #490703 2nd Oct 2018 5:39pm
dolph34
Thats it Stan Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #490704 2nd Oct 2018 5:42pm
mjdronfield
Sorry, it was for John W.
Re the rear ventilation button, do we know what it actually does? Does it just enable the climate controls in the back? Or just the hearer bit?
What are we actually turning on and off? Given the below, I recon it just enables the controls in the rear.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #490705 2nd Oct 2018 5:43pm
mjdronfield
Stan beat me....again. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #490706 2nd Oct 2018 5:44pm
Mr. Green
that button provides air flow to the rear and the rear knobs control the cold or warmth...
Post #490709 2nd Oct 2018 5:49pm
Woofster
Canada
According to the manual, it is called the rear control isolation switch.
The switch illuminates when the rear controls are active. By default, the rear controls are isolated. Air flow should be supplied to the rear at all times. It should also be noted that the temperature set by the front occupants restricts the maximum level of air the rear passengers can select.
Post #490724 2nd Oct 2018 7:25pm
Fart diverted button.
Leave well alone. There is nothing that can't be fixed with a hammer😜😜
Post #490726 2nd Oct 2018 7:49pm
CS
Agreed it is a bore to have to switch it off every time. I'm not aware of it being possible to programme it otherwise. I got used to it. Only Range Rovers since 1988
Post #490738 2nd Oct 2018 9:12pm
