Home > Technical (L322) > Replaced discs, STILL got brake judder |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 895 |
Have you checked for a seized rear caliper?
3rd Oct 2018 8:24pm |
Mulcher Member Since: 08 Aug 2016 Location: Shropshire Posts: 238 |
Thanks, I'll check for a hot wheel. Just so I completely understand, by "seized caliper" do you mean the brake pistons seized in the caliper bores? 2006MY 4.2 SC
4th Oct 2018 9:21am |
Yes, it can either be the piston corroded into the bore of the caliper (most likely) or the caliper carrier corroded and stuck (less likely).
4th Oct 2018 10:52am |
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 |
It isn't always obvious which wheel/brake is juddering. I had a judder felt through the pedal when braking heavily. The car passed its MOT so I didn't get round to sorting it out for a while. Only when I wanted to PX the car did I decide to fix the problem.
4th Oct 2018 2:08pm |
Just as an update for the benefit of others, the fault was eventually tracked to the rear nearside brake disc. A piece of the disc’s braking surface about the size of 50p piece had broken away, sort of delaminated to a depth of 1 to 1.5 mm.
12th Oct 2018 12:52pm |
Thanks for rounding off with a solution .
12th Oct 2018 2:03pm |
Full Fattie Member Since: 10 Aug 2018 Location: Sunderland Posts: 245 |
I didn’t think rear discs would warp but they did on a previous car. If you have a manual handbrake you can test the tears by pulling it on slightly while driving to see if you can feel it. |
12th Oct 2018 8:10pm |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 799 |
It always surprises me how such a big hunk of metal can be so sensitive to vibrations caused by things such as this
13th Oct 2018 1:01pm |
