Home > Maintenance & Mods (L322) > xenon 6000k
Page 1 of 3 123>
xenon 6000k
i fitted some hid 6000k bulbs over the weekend and they look a bit more bluer than the 4300k OE bulbs, well chuffed...not a very good pic [one replaced] but hopefully you'll see the difference.
Post #51455 22nd Feb 2011 9:42pm
GregP
United Kingdom 2002 Range Rover HSE Td6 Adriatic Blue
you can def see the difference Stan. The one of the right of the pic is loads better Wink Great work Thumbs Up FFRR TD6 HSE
Adriatic Blue with Parchment leather.
Post #51456 22nd Feb 2011 9:43pm
Thumbs Up greg...[you did mean left didnt you Smile ]
if anyone does want to do this make sure you get replacement bulbs with the four metal anti vibration tabs at the bottom of the glass bit otherwise the bulb wont fit.. ... - .- -.
Post #51458 22nd Feb 2011 9:50pm
GregP
yep, I did mean the one of the left Razz
Your side lights look bright as well. Mine are this dull orange colour. Have you upgraded those as well? FFRR TD6 HSE
Post #51459 22nd Feb 2011 10:01pm
yep, sides upgraded as well..
the ones on the left .
Post #51460 22nd Feb 2011 10:02pm
GregP
where did you get those from stan? easy to fit? FFRR TD6 HSE
Post #51461 22nd Feb 2011 10:08pm
got them off ebay and a piddle to fit.. ... - .- -.
Post #51463 22nd Feb 2011 10:12pm
GregP
these look different
http://cgi.ebay.co.uk/XENON-BLUE-LED-501-S...2eaa830e0f
are they the same sort of thing or not as good quality? FFRR TD6 HSE
Post #51466 22nd Feb 2011 10:19pm
those are the old type leds , you need the newer 'smd' type , sort of little yellow button type leds.. ... - .- -.
Post #51467 22nd Feb 2011 10:21pm
GregP
thanks mate.
You had any problems with the car thinking you have a bulb out due to the lower power needed on these newer lights? FFRR TD6 HSE
Post #51468 22nd Feb 2011 10:26pm
GregP
nice ones here for fogs
http://cgi.ebay.co.uk/H7-68-LED-FOGLIGHT-B...4154e0bc08 FFRR TD6 HSE
Post #51469 22nd Feb 2011 10:28pm
no problems with errors, in fact its quite cool seeing the sides flicker when the ecu does its check on startup.. ... - .- -.
Post #51470 22nd Feb 2011 10:30pm
daveo
6000 is a bit on the blue side for me, i think the merc's use 6000 i use 5500 they are a bit more whiter then standard, i swap my inner haligon's for led's H7 this gives you a sharp and quick light for flashing not that great on Censored roads but i live in london. the led indicator bulbs look great as well again bright and sharp flashes. V8 facelift Range Rover Autobiography 22" wheels.
Post #51472 22nd Feb 2011 10:44pm
i have leds in my inner halogens as well dave but use them as drls...the inners are crap as only 10 volts is fed to them thats if you have bi-xenons btw... ... - .- -.
Post #51473 22nd Feb 2011 10:50pm
daveo
hi my ones look ok,as i say they dont throw much light out but the bi xenon's will do that.. V8 facelift Range Rover Autobiography 22" wheels.
Post #51474 22nd Feb 2011 11:02pm
Page 1 of 3 123>
