Home > Technical (L405) > L405 "design faults"? |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7760 |
I'm not sure the remote tailgate is any worse than the manual one - or doors that still open the full way when you park next to a low wall.....
25th Dec 2018 5:34pm |
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2152 |
Terrible reversing lights. Alright to be seen by, but hopeless to see by when reversing in the dark.
25th Dec 2018 6:52pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3691 |
The vehicle needs a power tailgate disable function so that you can operate it manually if required. e.g. on the previous models you could just open the lower tailgate and keep the top closed so that you could stand on the lower tailgate with the top one closed to load a roof rack or the roof bars / rails with a kayak for example. Before you could just open the top slightly then drop the lower tailgate keeping the top one closed.
25th Dec 2018 7:21pm |
martinf Member Since: 26 Dec 2014 Location: sussex Posts: 256 |
In foggy conditions in daylight the auto lights often don't turn themselves on. In my MINI if I turn on the fog lights the headlights come on as well. It would be nice if LR followed MINI's example. |
26th Dec 2018 8:46am |
I don’t understand
26th Dec 2018 10:31am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34920 |
front fogs are for other road users to see your vehicle and are not necessarily for more front illumination although they do help...i'm pretty sure front fogs must be used with headlights . |
26th Dec 2018 10:46am |
pld118 Member Since: 25 Mar 2013 Location: Bairns Posts: 4218 |
The Road Vehicles Lighting Regulations 1989 - "Front fog lamp": A lamp used to improve the illumination of the road in front of a motor vehicle in conditions of seriously reduced visibility. “Front position lamp”: A lamp used to indicate the presence and width of a vehicle when viewed from the front. “Headlamp": A lamp used to illuminate the road in front of a vehicle and which is not a front fog lamp. Requirements about the use of headlamps and front fog lamps - 25.—(1) Save as provided in paragraph (2), no person shall use, or cause or permit to be used, on a road a vehicle which is fitted with obligatory dipped-beam headlamps unless every such lamp is kept lit– (a)during the hours of darkness, except on a road which is a restricted road for the purposes of section 81 of the Road Traffic Regulation Act 1984 by virtue of a system of street lighting when it is lit; and (b)in seriously reduced visibility. (2) The provisions of paragraph (1) do not apply– (a)in the case of a motor vehicle fitted with one obligatory dipped-beam headlamp or a solo motor bicycle or motor bicycle combination fitted with a pair of obligatory dipped-beam headlamps, if a main-beam headlamp or a front fog lamp is kept lit; (b)in the case of a motor vehicle, other than a solo motor bicycle or motor bicycle combination, fitted with a pair of obligatory dipped-beam headlamps, if– (i)a pair of main-beam headlamps is kept lit; or (ii)in seriously reduced visibility, a pair of front fog lamps which is so fitted that the outermost part of the illuminated area of each lamp in the pair is not more than 400 mm from the outer edge of the vehicle is kept lit; (c)to a vehicle being drawn by another vehicle; (d)to a vehicle while being used to propel a snow plough; or (e)to a vehicle which is parked. (3) For the purposes of this regulation a headlamp shall not be regarded as lit if its intensity is reduced by a dim-dip device. |
26th Dec 2018 12:35pm |
I’m not sure how many times I’m going to have to read that for it to make sense!
26th Dec 2018 12:41pm |
A cure for insomnia |
26th Dec 2018 12:47pm |
Indeed! |
26th Dec 2018 12:48pm |
+1 that was always my understanding as well and used to appear in the Highway Code as such 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
26th Dec 2018 1:49pm |
So you agree with me in the sense that you have to have the headlights on the operate the fog lights. |
26th Dec 2018 2:21pm |
I did not refer to front fog lights. Front fog lights were an option on my Vogue. My point is that if you want the rear fogs on in foggy but daylight conditions you have to put the lights onto manual. |
26th Dec 2018 2:24pm |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 |
I think this is why in a lot of vehicles the front fog lights will operate with just the sidelights switched on rather than full beam to stop glare as RM states. |
26th Dec 2018 2:46pm |
