Home > Technical (L322) > crankshaft bolt |
jk3528 Member Since: 28 Sep 2018 Location: stoke on trent Posts: 46 |
ok so lets have some ideas
6th Oct 2018 7:00pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2303 |
Not your engine but the crankshaft bolt in a TDV6 is normal RH thread. |
6th Oct 2018 9:21pm |
Thanks but as you said mines the 4.4 m62 |
6th Oct 2018 9:47pm |
The picture in this link shows a RH thread on the bolt.
6th Oct 2018 10:13pm |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 |
It’s a normal right hand thread and you need the locking tool and even then I used a scaffold tube and 3/4 bar. I broke a 3/4 swivel head bar and had to use a sliding bar instead. You are at risk of damaging your relatively thin starter ring and then you won’t be able to time your engine correctly. The locking pin is for timing purposes only. I’ll post some pics of when I did mine.
7th Oct 2018 7:26am |
This is the correct tool to hold the crank while undoing the bolt, it’s a big lump.
7th Oct 2018 11:23pm |
Yep got one on order and a 3/4 drive socket |
7th Oct 2018 11:26pm |
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 218 |
Dont forget the piece of pipe. |
7th Oct 2018 11:49pm |
My breaker bar was over 5 ft long , bought a good scaffold tube off eBay guy for £6.
8th Oct 2018 12:33am |
Not done it on a RR but in the past when undoing a crank bolt I jacked the front of the car up put the socket on the bolt with the breaker bar fitted with the end of the bar on the drive or piece of timber and then let the jack down leaving the weight of the car on the breaker bar. Went for a coffee for a while whilst the weight of the car and gravity undid the bolt.
8th Oct 2018 7:26am |
Undone that bolt yet ?? |
16th Oct 2018 8:10pm |
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 |
Nice I've used a similar trick for hub nuts in the past. |
16th Oct 2018 10:15pm |
All done now quiet easy with the right tool |
16th Oct 2018 11:59pm |
17th Oct 2018 5:20am |
