Home > Technical (L322) > Need a 4.4 TDV8 FBH guru |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1097 |
Hi folks,
10th Oct 2018 6:33pm |
Thanks Dolph, in the wheel arch? Current: 2011 FFRR Vogue SE 4.4 TDV8
10th Oct 2018 6:57pm |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
Yes sir, on a cold day it can scare the hell out of you when you see smoke coming out the side of the car. 2015 4.4 AB
10th Oct 2018 6:58pm |
Well that would explain why I can't find it then.
10th Oct 2018 7:01pm |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 895 |
As Dolph says, it's behind the nearside wheel arch, under the battery.
10th Oct 2018 7:04pm |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
Remove batteries from remote for 30s. Replace batteries. Pull fuse 16 in the boot. Hold off down on the remote. Push fuse in while continuing to hold off on the renotr. Wait for remote to flash. Job done. Did it last nihht on mine Land Rover Addict
10th Oct 2018 7:08pm |
Not connecting the fan is unbelievable, a friend of mine with a 2 year old merc had a similar problem when a merc main dealer forgot to reconnect the fan , my friend has no mechanical knowledge or common sense and kept driving it on a hot day a blew the head gasket, i had a quick look and the fan connector was lying loose !!! It might be worth a check to see if its all connected up as it should be. Did you try running it from the display screen ? 2015 4.4 AB
10th Oct 2018 7:10pm |
No, only tried running it from my IID tool
10th Oct 2018 7:29pm |
Well that means it's paired. There must be another issue if its now not firing. Does the vertical orange light come on in the cabin when you press on - I fact does the light on the fob go from Amber to green? " Land Rover Addict
10th Oct 2018 7:45pm |
No, pressing the on button on the fob just results in red flashing LED
10th Oct 2018 7:53pm |
I'm on my mobile so can't see what version of the l322 you have. If it's pre 09 then it's above the 'on' switch for audio etc.
10th Oct 2018 8:00pm |
It's a 2011, will give it a go tomorrow morning Current: 2011 FFRR Vogue SE 4.4 TDV8
10th Oct 2018 8:11pm |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 385 |
I would have thought the remote is irrelevant. It should operate from the IID Tool. I assumed this would be independent of outside temperature since it is for diagnostic purposes.
11th Oct 2018 6:57am |
As far as I can understand IID does operate regardless of temperature.
11th Oct 2018 7:35am |
