Home > Technical (L322) > IID Tool Code Help - Airbag SRS Light
Happy Eater
Hi
I have a GAP IID tool - absolutely brilliant bit of kit. Even just for the graphs it can do in real time stuff.
I have a 2007 Vogue SE TDV8 3.6 and the Airbag SRS light comes on with Ignition, goes out for a few seconds then comes on again and stays on.
I have read the code and it comes back with.
B1198-13 (AA) Drivers side inflatable tubular structure - General electrical failure - circuit open.
Has anyone got any ideas based on the code above?
Many thanks
John
Post #491858 11th Oct 2018 12:59pm
Sandyt
I had similar and spent a fortune changing bits and testing stuff it turned out to be the steering column spider which sits on the steering column and completes the circuit
It doesn't come up as a specific code mine was intermittent so I changed passenger side airbag for a new one from memory about a grand and two weeks later it was back
Do you hear every now and then a sort of rubbing going from lock to lock I would try that first
Post #491906 11th Oct 2018 8:03pm
Happy Eater
Thanks for the response.
I suspected the Clockspring initially..
However, after reading the Workshop Manual I found the full suite of codes in the SRS sections. Thanks Forum Wiki
It seems to indicate a Driver side curtain airbag circuit short to ground, so that gives me something to go on!
It might be a while but I will report back..
Post #491908 11th Oct 2018 8:27pm
