Home > Technical (L322) > check side light / front light warning ?
bembo449
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
but everything is working just fine , this started happening yesterday , any ideas guys ? Confused
Post #491910 11th Oct 2018 9:09pm
stu1
Poor/intermittent contact and/or filament broken on sidelight. I've had this on every single one we've had at one time or another and it's either been the bulb itself or the bulb holder contacts.
Post #491915 11th Oct 2018 9:59pm
Canbus errors due to LED lights ? .
Post #491921 11th Oct 2018 10:19pm
bembo449
its not miss behaved today at all , most be the time of the month , my LEDs are wired into the fusebox Joe90 so it cant be that pal lol
Post #492010 12th Oct 2018 7:42pm
gilesharrison
United Kingdom 2008 Range Rover Vogue TDV8 Stornoway Grey
I have put some Osram LEDs in mine and I kept getting the error despite the fact that they're meant to be CanBus error free. After messing about with the contacts for a while, I just decided to turn of the hot monitoring and cold monitoring to the bulb in the CCF. Love the IID Tool!
Post #492016 12th Oct 2018 8:22pm
Therefore it has nothing to do with the lights, but the wiring that used to be connected to them ? Helps when you get a full description of the issue Twisted Evil
Is the original wiring properly isolated, and IIRC you can turn off the hot monitoring (unfortunately on your model not the cold monitoring IIRC) on the sidelights, which may prevent recurrence. .
Post #492040 12th Oct 2018 11:12pm
