Home > Technical (L405) > Overrevving ‘run a way’ TDV8 then engine died |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1458 |
https://www.youtube.com/watch?v=Cqb7l-_P_nE
14th Oct 2018 4:27pm |
It only needs the failure of an oil seal on a turbo and the rest is history, a minor defect causing a major failure.
14th Oct 2018 6:42pm |
Richardince Member Since: 14 Oct 2018 Location: Suffolk Posts: 39 |
No Warranty unfortunately, myself and wife are so upset this has happened on the first day of a week away in Yorkshire.
14th Oct 2018 7:15pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
Geez that other guy was also on 115k
14th Oct 2018 7:40pm |
£115,000 to buy 60,000 miles |
14th Oct 2018 7:50pm |
So sorry, I suppose the bright side is no one got hurt. A very bitter pill to swallow I hope you can find some pleasure in Yorkshire, its breathtaking in places. BMW i3 Electric Car
14th Oct 2018 8:45pm |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2301 |
Unfortunately it doesn't help with your vehicle Richard, but it could be useful to know whether or not your vehicle's secondary turbo drain is the later twin drain style. |
14th Oct 2018 10:24pm |
ABAB Member Since: 02 Feb 2017 Location: GB Posts: 266 |
Very sorry to read this story. Is TDV8 the same as SDV8 or is the design different? I seem to recall that both TD & SD (albeit V6s) were available for the Discovery at one point. 2016 SDV8 AB |
15th Oct 2018 8:05am |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1340 |
ABAB, my understanding is that the engines are basically the same but 405 version set up for more power (perhaps because lighter car). I think the earliest 405s had the old style turbo drain (i.e. mod desirable), not sure when that was changed, maybe would have been by the time of the 2014 car here.
15th Oct 2018 12:08pm |
Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409 |
just had new engine from LR in mine. make sure your sat down.
16th Oct 2018 9:40am |
SilverParrot Member Since: 09 Aug 2018 Location: Herts Posts: 25 |
It is quite common on the TDV6 as fitted to the S-type Jag. The cause in this case is oil dilution with fuel due to failed DPF regens and the engine runs on the oil. I believe this was due to poor software handling of the DPF regen. Not heard of this cause on LR engines. I also know of someone who had this happen on a Pug. |
16th Oct 2018 10:24am |
There were very high winds at the time whilst going up 25% gradient hill. Could this have been a factor? |
16th Oct 2018 10:29am |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 837 |
Does this very unfortunate event point to the turbo drain mod on all 4.4 TDV8's being more preventative than just dealing with the undesirable smoke when the second turbo cuts in, or have I misinterpreted the potential source of the oil entering the combustion cycle? |
16th Oct 2018 11:17am |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
This is sad news. It seems there is a club forming of owners with dead TDV8 Range Rovers Land Rover Addict
16th Oct 2018 12:08pm |
