Home > Technical (L322) > Air suspension leak - typical culprit and upgrade parts? |
gj88 Member Since: 10 Sep 2018 Location: West Midlands Posts: 213 |
It's probably most likely the bag (bellow) that's gone, particularly if you've heard the air escaping. Could be a hose or something, but on the age of yours (and assuming that they're original) the bags are frankly overdue to go. The EAS can shut down completely if the bags gone, so the suspension lights on the centre console will all be out, if this is the case you'll need diagnostics to get it up and running again, an IID tool will do the trick.
16th Oct 2018 1:48pm |
PIMCO Member Since: 30 Jul 2018 Location: Oslo Posts: 44 |
Thanks for the reply.
18th Oct 2018 9:57am |
Best to get the Delphi ones from island 4x4, once you understand the shipping cost
18th Oct 2018 11:11am |
Unnecessary quote removed
18th Oct 2018 11:31am |
Shipping it turns out was a cool 30 pounds, so that's quite alright. Think I'll opt for Island 4x4.
19th Oct 2018 11:43am |
I didn't try to take it off in access mode, but if you drop the car to that level and have a feel of the bag, you'll probably find that even in that mode there's an awful lot of pressure in there. The main issue is being under a car that's jacked up and is going to drop when you disconnect the hoses, I for one wouldn't want to be anywhere near it when it drops, just in case!
19th Oct 2018 12:38pm |
GI JIM Member Since: 23 Jan 2012 Location: Scotland Posts: 41 |
There is a video on RSW on changing the struts I followed it on my old 2002 TD6 with no problems May The FFoRRce Be With You |
19th Oct 2018 1:34pm |
Cooper1275 Member Since: 02 May 2016 Location: Dublin Posts: 117 |
Great write up here
19th Oct 2018 1:47pm |
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 |
Better to use penetrating oil.
20th Oct 2018 12:52pm |
Yes absolutely correct penetrating fluid is the one you need, i keep saying wd40 by force of habit. |
23rd Oct 2018 9:45am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34913 |
wd40 is a multi purpose lubricant and penetrating oil,
23rd Oct 2018 11:49am |
Thanks for the input, fellas.
24th Oct 2018 4:28pm |
Has it thrown up the warning that EAS is inactive, or have the lights on the suspension control switch all gone out too? If it's the former, you should be able to clear it by turning the steering to left full lock for a few secs, then right full lock, then back to centre, that should sort it. If the lights are all out too then it's a hard fault and it'll need diagnostics. That may be a dealer job, but if someone around has an appropriate tool (the IID tool works a charm) then that would be significantly cheaper |
24th Oct 2018 6:47pm |
Yeah, neither had lights in selector button and the message center read "EAS inactive" or something similar. My RSW software tool seemed to take care of this by deleting the fault codes, tho.
1st Nov 2018 9:17am |
