Home > Technical (L322) > Door card removal |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3057 |
Shouldn’t be - can’t see any change on mine from when I changed my 2004 dvrs door card. |
17th Oct 2018 1:03pm |
funnyguy1 Member Since: 11 Mar 2010 Location: Sun Valley, Idaho Posts: 378 |
Thank you! Can the door handle cable installed without unhooking all the electronic cables?? |
17th Oct 2018 3:33pm |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1193 |
Removed for a glass replacement, this photo gives an idea of the passenger door on a right hand drive car, I assume the driver's door on a left hand drive is similar.
17th Oct 2018 3:47pm |
Not really a good idea as you need to support the door card then. It also puts strain on what are pretty flimsy cables which could snap. Just take a photo of the wires in situ and then replace. |
17th Oct 2018 3:48pm |
I'll clarify:
17th Oct 2018 3:55pm |
Thank you all!! Great info. I also ordered new door panel
17th Oct 2018 8:09pm |
fg1
17th Oct 2018 8:32pm |
Knightmare Member Since: 22 Jun 2015 Location: Kent Posts: 84 |
I've just done the same thing on the driver's side to replace a blown speaker. The great British weather then decided to release a monsoon just as I got the door card off. Fiddly is an understatement when you're outside, can't shut the door and only have one pair of hands.
18th Oct 2018 9:10am |
Sir Knight
18th Oct 2018 6:03pm |
Thanks for the tips.
18th Oct 2018 6:08pm |
Good luck and look forward to hearing it's fixed Cheers
18th Oct 2018 6:31pm |
Yay, all sorted...well kind of. What a difference a dry sunny day makes!
20th Oct 2018 6:38pm |
20th Oct 2018 7:20pm |
Hi RJFF,
25th Oct 2018 12:42am |
