Home > Maintenance & Mods (L322) > Remanufacturing Torque converter - 07 TDV8 ZF 6hp26 |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 910 |
These are the people that I always use : https://www.jpat.co.uk/torque-converter-remanfacture.html
22nd Oct 2018 6:25pm |
S.Hafsmo Member Since: 02 Oct 2018 Location: Nordland Posts: 170 |
Much appreciated, Phil. Do you know how much they usually charge for such a job? I was quoted £800 on this side of the North Sea.
22nd Oct 2018 6:56pm |
srpara Member Since: 03 Oct 2013 Location: moray Posts: 115 |
I can recommend Mackie transmission had work done by them on my previous range rover 👍 |
22nd Oct 2018 10:39pm |
The last (re-manufactured) 6HP26 torque converter that I bought, earlier this year, cost just under £290 delivered. I assume that your £800 quote included fitting? If it also included new fluid, then it’s a reasonable quote.
22nd Oct 2018 11:09pm |
The RPM jumps 100-200 rpm at light throttle/low speed (30-40mph). This is supposed to be Controlled slip, is it not?
23rd Oct 2018 4:55am |
An update on the matter.
23rd Oct 2018 5:39pm |
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 334 |
I got the oil from Advance factors when i worked on my box a few years back - they are a forum sponsor. |
27th Oct 2018 2:04pm |
try autodoc for the pan/filter, I just got my genuine ZF one form them for a fraction of the LR and OEM prices, and its the proper thing.
27th Oct 2018 2:28pm |
I found a local vendor who stocked LG6 and bough a Box (12l). I was able to fill a whole litre while standing in the driveway (so not 100% certain the car was completely Level), and it made a big difference to the converter slip. The problem has not disappeared, but it now only occurs on very rare occations.
2nd Nov 2018 6:12am |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 416 |
Just to add my recommendation for Sussex Auto, they went out of their way to sort a refurb unit on my torque converter (on a 5HP24) after I took mine down to them. I was planning on dropping it off and picking it up later that week as they didn't have a replacement in stock but they offered to do it while I waited (about 1-2 hours). When I said I couldn't wait they then hunted for an exchange unit from a large batch recon order they had just completed which they regularly get in from Germany so to save me a return trip.
2nd Nov 2018 9:55am |
Another update on this issue. I've done a filter/oil change/mech-sleeve this weekend and was able to fill approx. 6-7l after letting it drain over night. Filling done acc. to ZF procedure.
28th Nov 2018 3:31pm |
m@ttsFF Member Since: 12 Dec 2017 Location: Surrey Posts: 326 |
There are always boxes and TCs on UK eBay around 6-700 GBP
28th Nov 2018 6:22pm |
I've found a couple on ebay, and one mentions a shipping cost of approx. £300, which is not a problem at all.
2nd Dec 2018 9:26pm |
If you source one off eBay, just to be on the safe side I would double check with the seller that you’re getting a 1068 020 075 model with the Y94 torque converter.
3rd Dec 2018 1:27pm |
