Home > Maintenance & Mods (L322) > Anoying L322 |
A.Pires Member Since: 02 Dec 2016 Location: Seixal Posts: 137 |
I start to be disappointed with my Vogue L322. First it started with a knock at the right front suspension zone. I've replaced all the suspension arms, joints and brake pads. I've already undone everything and reattached it and the beat does not disappear. Then started with a squeak in the rear suspension almost looks like an ox wagon. Neither my 2A series with leaf springs made this noise. Then it started with a noise coming from inside the dashboard when I open any of the doors. This noise sounds like a little hammers hitting something. After a few seconds it stops.
24th Oct 2018 1:15pm |
SidewaysMatt Member Since: 25 Feb 2016 Location: Ledsham, Cheshire Posts: 173 |
Re the noise from the dashboard, is this any help:
24th Oct 2018 2:03pm |
Hello,
24th Oct 2018 2:31pm |
NobbyC Member Since: 29 Dec 2015 Location: Princes Risborough Posts: 118 |
Re the squeak - quite common but before you go replacing suspension bushes etc, a cheap fix might be to check the routing of the handbrake cable as often the cable casing rubs through against the eyelets etc on both sides and then squeaks particularly over the slightest bumps.
24th Oct 2018 7:53pm |
Hi NobbyC
3rd Nov 2018 3:39pm |
Front end knocking, have you replaced the anti roll bar links (use LR ones if you do) .
3rd Nov 2018 4:08pm |
Hi Joe
3rd Nov 2018 4:58pm |
