Home > Maintenance & Mods (L322) > New ball joints on Sunday, any tips? |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 |
good quality ball joint splitter. Had to beat the living Cr@p out of mine with a sledge hammer to get them to release 56 TDV8 Vogue SE
26th Oct 2018 5:47pm |
mark35gun Member Since: 01 Oct 2018 Location: swanwick Posts: 63 |
don't forget the warm gloves and tea and big hammer 2011 4.4 tdv8 autobiography black
26th Oct 2018 6:30pm |
Springer Member Since: 15 Nov 2017 Location: Merseyside Posts: 104 |
Hi let us know how you get on as I need to do mine
27th Oct 2018 8:09am |
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 |
Totally this. I’ve had jobs in the past where I’ve gone through 3 on the same job. And heat. |
27th Oct 2018 9:15pm |
srpara Member Since: 03 Oct 2013 Location: moray Posts: 115 |
Loads of heat on ball joint on hub plus wd40 or similar and large hammer |
27th Oct 2018 9:29pm |
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 719 |
They ended up staying in place, b@st@rd things. Replaced the arms but left the ball joints as they were still ok, and nigh on impossible to get out. |
29th Oct 2018 5:14pm |
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 |
same results as me!
30th Oct 2018 1:48pm |
oh, and replacing both the arms has actually cured all my noises from that corner even though i was trying to do the ball joint as well. however, the forky thing used to split the ball joints has ruined the boot on the ball joint in the process! |
30th Oct 2018 1:50pm |
sorry for the thread hijack but this was how my attempts to sort the ball joint developed...
30th Oct 2018 2:08pm |
interested to see if anyone replies to you Dexion, as i couldnt see how to shift them either. We contemplated heat but was worried about the other ball joint and the CV boot too... Took her for a 10 miles test yesterday and the annoying knock has gone, so very pleased with that |
30th Oct 2018 4:52pm |
I've been driving around with new arms and a hithertoo good ball joint which now has a knackered boot for 2 weeks now. Since I'm doing this all on the drive I'm losing enthusiasm since the weather has turned and i've still only done part of one corner!
30th Oct 2018 5:55pm |
You can just get new rubber dust covers if ball joint is still good |
30th Oct 2018 8:47pm |
Those strut bolts can be a bit of a pain... |
30th Oct 2018 9:00pm |
When I changed the bottom ball joint I used a flame resistant blanket ( like they use when plumbing in a sensitive area) to protect the CV boot
30th Oct 2018 9:19pm |
