Home > Maintenance & Mods (L322) > Battery life |
10 years, that is good!
4th Nov 2018 1:52pm |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 666 |
Unusually good life - maybe it's been "cossetted" with a trickle charger when not in use for any time.
4th Nov 2018 6:14pm |
Thats lastes extraordinarily well! And a damn fine reason to stick with genuine batteries... |
4th Nov 2018 6:30pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7753 |
5 years is my rule of thumb - but I usually wait for the first sign of a problem, then replace.
4th Nov 2018 8:25pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3673 |
I sort of agree with Alistair, mine seem to last either 5years or 5 minutes
4th Nov 2018 8:32pm |
V8Noise Member Since: 25 Apr 2015 Location: Dereham Posts: 423 |
Just changed the battery in SWMBO's Smart. That was the original from 2008. Certainly for the last 5 years it's been cosseted on a C-Tek although it does lots of short runs. 2017 5.0 Autobiography Supercharged
4th Nov 2018 8:51pm |
Did my disco last year and that was an original on a 2010 so 7 years, the 4.4 is still on its original at 6 years, swmbos old Skoda lasted 10 years.....
4th Nov 2018 9:00pm |
I changed my 2011 battery in June, not because it had failed, but because I didn’t want it to let me down on the first freezing morning of winter and have to do it in the cold.
4th Nov 2018 9:11pm |
ptaroni Member Since: 20 Dec 2015 Location: leicestershire Posts: 89 |
My 07 tdv8 is still on its original battery!! No signs of failure as yet, used my pre heater every morning on full cycle for around 6 weeks now too, every time i start it im expecting the hdc warning like my old td6 used to throw before i replaced the battery! I know now ive said this failure is around the corner! 2004 td6 l322 - gone
5th Nov 2018 8:34pm |
SidewaysMatt Member Since: 25 Feb 2016 Location: Ledsham, Cheshire Posts: 173 |
I replaced the battery in mine a few months ago. It was the original battery from new (2004). I was impressed! Only changed it as it went flat after being left 2 weeks in an airport car park. Shoved a Yuasa 020 in from Halfords, let's see how long taht one lasts 2004 Vogue TD6 - Remapped
5th Nov 2018 9:26pm |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 385 |
I've just very recently changed the original battery on my 2010. The only issue was that the FBH wouldn't fire (rest voltage was low at 11.4V). Everything else seemed to work ok though. 2010 4.4 TDV8 Vogue SE |
6th Nov 2018 8:50am |
Land Rover & Rover used to be well known for replacing batteries on very new cars because of the number if unsold cars stored on local airfields etc & left with stupid things like interior lights on,. The cars would be jump started eventually
6th Nov 2018 10:14am |
