Home > Technical (L322) > No heat from vents FIXED |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 |
You have my sympathy, looks like you've tried everything .
5th Nov 2018 7:50pm |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3050 |
Sandyt had this problem as did I. It has possibly something to do with the heat exchanger in the front engine bay. I fixed mine by removing and reinserting the pollen filter. It worked after several attempts. Still don’t know why but it’s been fine since (4 years) |
5th Nov 2018 7:51pm |
Ridgeback Member Since: 11 Apr 2018 Location: Ipswich Posts: 11 |
Many thanks will follow the hot water n recheck pollen filter |
5th Nov 2018 11:07pm |
rik Member Since: 21 Jan 2015 Location: argyll Posts: 265 |
Pretty sure you still have air lock they can be a swine to bleed I found a good way to bleed was using a 2litr bottle of coolant and stand upside down on expansion tank open bleed screw and run engine keep a full bottle ready to replace do not allow expansion bottle to empty make sure heater control is at max .If that don't work you may have a blocked radiator good luck |
5th Nov 2018 11:14pm |
Many thanks for the replies Tried bleeding it again still the same Bit the bullet n took to my local RR specialist Landypart Woodbridge They put a fault reader on & forced the heating system A code was up n was cleared n returned A thermostat Not sure if this is coolant system or heating £260 to replace Will advise what stat when I know n if it worked |
8th Nov 2018 12:56pm |
Update us all once you have it sorted.
8th Nov 2018 6:09pm |
Which engine bmw or jag ? |
8th Nov 2018 9:02pm |
UPDATE
7th Dec 2018 11:22am |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 816 |
I heard of a way to bleed these things is to jack the front of the car way up.
7th Dec 2018 11:43am |
Thanks Simon
9th Dec 2018 11:24am |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2213 |
Just a thought I had to seriously overhaul the whole heating system and found that there was a another valve on the bulkhead which was connected to the FBH (mine is one of the few petrols with it) this was my main culprit the valves on the inner wing were replaced but the one on the bulkhead was stuck shut and not allowing any hot water to the matrix there was no airlock
9th Dec 2018 5:52pm |
Mine hasn’t got the FBH So does it still have the valve ? |
9th Dec 2018 6:07pm |
Not sure to be honest if so it is low down where the pipes go through the bulkhead to the heater matrix |
9th Dec 2018 6:28pm |
Ah that could be why mine was cold .... it too is petrol with an FBH. Maybe taking everything out allowed the bulkhead valve to open? |
9th Dec 2018 6:41pm |
