Home > Maintenance & Mods (L322) > Brake pipe repair now completed |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1271 |
Who are you usung henda
17th Nov 2018 1:20pm |
Just make sure he takes the covers off on the front to rear pipes (up in the channel) they will be all rotted to hell .
17th Nov 2018 1:38pm |
Henda Member Since: 02 Aug 2018 Location: Gateshead Posts: 282 |
Yes joe that's what he said which is why I thought he seems to know what he's on about
17th Nov 2018 4:15pm |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3641 |
Yes don't mess about, I had a high speed trip back from Scotland with 4 blokes and 4 bikes when I got home I noticed a puddle on the driveway - yes you guessed it - Brake Fluid. Without warning a pipe had burst and I had to drive it to a nearby Indy to get it fixed. As any new fluid (and I used plenty) just out, I was on the handbrake which worked well but just locked the back wheels so I went in the dead of night (no traffic) and shoved my keys though the door.
17th Nov 2018 6:04pm |
Lucky
17th Nov 2018 7:10pm |
Andy Member Since: 24 Feb 2009 Location: Shropshire Posts: 2926 |
I replaced both front to rear lines myself. They are a bit tricky to do but they come from Land Rover pre-shaped at around £12 each. The nearside is easy to do but the offside is L shaped to run across the rear of the car. That’s the tricky one! |
18th Nov 2018 3:53pm |
Do they both run down the near side under the plastic cover and are the brakepipies from LR a stock item or do they need ordered |
19th Nov 2018 9:33am |
Yes that’s correct. Remove the plastic covers and you’ll see them. They corrode on the exposed sections.
19th Nov 2018 9:46am |
FF is in the garage for brake pipes and the guy just rang saying the rear flexi-pipe on the near side has gone as well told me to pop down and take a look so he seems an ok guy
22nd Nov 2018 2:50pm |
So the FF went in for a leaking front to rear brake pipe and as I expected I've had both front to rear pipes and both rear flexi pipes needed doing
23rd Nov 2018 8:30pm |
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 |
I'd say that was a very good price |
23rd Nov 2018 8:52pm |
