Home > Technical (L322) > Rear passenger door stuck shut! |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 |
Open the front door and undo the bolts holding the rear door on. When you can pull the front of the door out, pop the door card to get your hand in and release the lock. Two man job though. Try another way and you'll be buying a new door card. Good luck. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
2nd Dec 2018 4:43pm |
Snowy90 L322 Member Since: 24 Aug 2015 Location: Surrey Posts: 220 |
Oh Crap,
3rd Dec 2018 11:51am |
Dont mess with hinge pins. Take the bokts on the B post out and open the door. That wiil allow the door card to cpme off. Go from there 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
3rd Dec 2018 2:32pm |
Just a thought regarding your door panel. I think you could probably remove your door panel in situ using a piece of flat steel strip with the end turned at right angles for about 10mm.
8th Dec 2018 7:15pm |
