Home > Technical (L322) > Exterior door handle not working? |
Snowy90 L322 Member Since: 24 Aug 2015 Location: Surrey Posts: 220 |
im having the same problem, my rear passenger door is stuck closed, only remedy at the moment is taking the door off as i cant open it to get the door card off.
3rd Dec 2018 1:29pm |
Maybe try pulling the fuses or a battery reset first. |
3rd Dec 2018 1:30pm |
kds2 Member Since: 30 Sep 2017 Location: lincoln Posts: 218 |
Had to replace the cable to outer handle not long ago, the nipple had seized at handle end so instead of turning slightly it was twisting the inner which snapped had to take handle off in the end to remove nipple gave it a coat of copper grease on refitting new cable hope it helps stop it seizing up. |
3rd Dec 2018 10:17pm |
PIMCO Member Since: 30 Jul 2018 Location: Oslo Posts: 44 |
So both your outside and inside handles are not working, Snowy? You can probably feel from the resistance of the handle whether the mechanical rod(s) have disconnected/broken or whether the door is merely locked.
7th Dec 2018 3:27pm |
yes very little if any resistance on the outside handle.
7th Dec 2018 3:52pm |
Also i can hear the lock doing something, when i try and lock and unlock!? |
No photo sorry, it was the nipple on the end of the cable that had sheared off, I guess once I had got the nipple out the lever arm maybe could have drilled it out then silver solder inner cable back on but then it would have meant shortening the outer cable to suit so just not worth the bother for the price of new complete cable. |
7th Dec 2018 5:19pm |
NVB Member Since: 14 May 2017 Location: Essex Posts: 103 |
Had the same on the drivers door in the summer. Would open from the inside, but not the outside. Bought a cheap generic cable from eBay and all is well again. RR History
7th Dec 2018 8:09pm |
ARH Vehicle Logistics Member Since: 28 Jan 2012 Location: Shropshire Posts: 61 |
I've had this happen to me twice in the last 5 years, buy a cable off fleabay and it easy to fit. If i could would you!!!! |
8th Dec 2018 4:46pm |
8th Dec 2018 7:10pm |
Considering the availability of China sourced cables on eBay - this problem must be more prevalent than I figured. Cable ordered, hopefully it arrives before Xmas so I can put it under the tree first. |
14th Dec 2018 1:41pm |
Well just to conclude! I have put this off for ages not really wanting to take the whole door off, then suddenly one morning it opened! Gotta love a Landrover!
9th Jan 2019 5:40pm |
