Home > Technical (L322) > A VERY different turbo noise. Not a Whine 3.6 TDV8 |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2303 |
Carefully check the top i/c hose for a split, commonly underneath. |
13th Dec 2018 8:39pm |
Panter89 Member Since: 13 Dec 2018 Location: Perth Scotland Posts: 3 |
Thanks for the reply, The strange thing is that the sound is coming from down in the RH side.
13th Dec 2018 9:15pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34911 |
this forum is for the larger fullfat range rover...
13th Dec 2018 10:02pm |
Nick591 Member Since: 04 May 2017 Location: Charfield Posts: 193 |
Someone else with similar symptoms on a fullfat found that they had a split in the inlet manifold which is not too uncommon. They had whistle and limp mode driving steadily up a hill on a fixed throttle. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8 |
14th Dec 2018 2:10pm |
Ok I now know what the difference is. Totally new to RR
14th Dec 2018 7:46pm |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
Good luck with it Tom. You will find a couple of recent threads on this problem on the 3.6. They might give you some indication of the work required.
15th Dec 2018 11:41am |
