Home > Maintenance & Mods (L322) > First Signs of Rust!! |
Just spotted this today :
2nd Mar 2011 3:39pm |
On ALL the time Joe on ALL the time |
2nd Mar 2011 3:42pm |
GregP Member Since: 11 Dec 2010 Location: Exmouth Posts: 1084 |
I have some similar bubbles under the plastic trim that surrounds the windows. unsure if I can get rid of them.
2nd Mar 2011 3:46pm |
You may joke - but you know it's true
2nd Mar 2011 3:49pm |
I wonder if it's had a dodgey repair there in the past? The paint looks a bit un-even, it's not unheard of for damage to occur in the factory/delivery and be patched up prior to going on sale. |
2nd Mar 2011 4:13pm |
paneldamage Member Since: 11 Nov 2010 Location: Preston Posts: 222 |
Mine had this when I bought it, plus some rust at the top where it meets the D post cover. My body shop mate stripped it back and found it was due to a poor quality repair at some point in its past.
2nd Mar 2011 11:21pm |
nick h Member Since: 26 Jan 2011 Location: notts Posts: 782 |
is this the trim at the 'top' of the door (below the glass?) if so i've got 'bubbling' underneath three of the windows its basically a plastic/rubber sleeve over a metal 'core' - so moisture gets underneath and it rusts from the inside - appearing as bubbles i am replacing all mine - cost £126 from Yeovil Land Rover (recommended on here for discount parts) |
3rd Mar 2011 4:30pm |
Thanks nick. I'll give them a call when replacing it. FFRR TD6 HSE
3rd Mar 2011 7:02pm |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 |
I was thinking that the vast majority of RR panels were aluminium and so not easily rust prone ,so are the rear panels just 'standard' metal then? Steve
4th Mar 2011 12:39am |
Not only are they metal - but they're steel. |
4th Mar 2011 12:50am |
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 |
What is the Land Rover description of the trim below the glass as I would like to replace mine |
31st Mar 2011 7:00pm |
L322 Pilot Member Since: 07 Apr 2011 Location: Solihull Posts: 13 |
On my 2002 L322 I have exactly the same rust spots on the nearside rear quater panel. I had it checked
12th Apr 2011 7:45pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
Wash your mouth out! Of course the aircon being on is the answer to everything! Ask Dan. Lol |
12th Apr 2011 8:52pm |
The rust burst through at the weekend, so will have to see to it now . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
12th Jul 2011 11:12pm |
