Home > Technical (L322) > L322 TD6 Front Brake Pads - Spring Clips into Piston |
tony66 Member Since: 01 Dec 2014 Location: fife Posts: 92 |
i just bought pads for mine-i think there are two types[not inc the brembos] one has ears with little anti rattle shims-the other has the big clips you describe...i may be wrong and havent fitted mine as yet |
14th Dec 2018 6:50pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3192 |
To th OP - re_use the spring clips that are already there. They aren't normally supplied with new pads. John
14th Dec 2018 6:56pm |
stuart_2006 Member Since: 18 Jul 2018 Location: Holsworthy, Devon Posts: 113 |
OK, so it looks like the front brakes changed for the 6A VIN. The Rimmer video shows the pre-6A version. Looks like I've got the correct parts - looking at my brakes with a torch through the wheel slots, I've got the 2 spring clips per side, and there are two bolts to remove the calliper carrier each side - two pairs of replacement bolts came with the pads. |
15th Dec 2018 12:22am |
