Home > Technical (L322) > Whirring noise from engine (possibly LH side) 4.4 TDV8 |
Sonearly Member Since: 18 Sep 2020 Location: Northants Posts: 213 |
Would be interested if this got resolved |
3rd Jan 2021 3:24pm |
4434Morrison Member Since: 02 Mar 2020 Location: Folkestone Posts: 185 |
Also interested in following this thread as I have a similar noise. 2012 4.4 TDV8 Vogue SE Current
3rd Jan 2021 5:11pm |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
Water Pump bearings maybe?
3rd Jan 2021 6:08pm |
Have replaced belt tensioner and three of the idler pulleys as they were showing wear. I have a stethoscope type of tool I’ll see if I can get to water pump in the morning and give it a go.
3rd Jan 2021 8:13pm |
coopss Member Since: 21 Apr 2018 Location: Hampshire Posts: 281 |
I noticed something like this after a service. I’ve not noticed it outside, only in the cabin. Same scenarios are you’ve described 1995 4.6 v8, green/tan (long gone)
3rd Jan 2021 9:39pm |
Same as mine, can’t hear it when seated in the back. Still got an annoying whine coming from the front drivers seat, which I know is very expensive to replace, should have checked before marrying her. Thank god she never reads this.
3rd Jan 2021 9:46pm |
Water pump seems fine. Will try releasing belt and running without to try and eliminate idler pulleys and ancillary components. Definitely seems to be less responsive on first start up in this colder weather for a couple of minutes, but it might just be paranoia. |
4th Jan 2021 12:00pm |
Hi
9th Jan 2021 10:15pm |
That’s interesting - do you have a picture of the part? 1995 4.6 v8, green/tan (long gone)
10th Jan 2021 7:26am |
You have two under engine shields that cover whole area. You can’t miss them. My issue was with the back one that was missing screw. Worth checking all of it for missing fixings. |
10th Jan 2021 9:14am |
That would be a nice find and a good fix!
10th Jan 2021 1:24pm |
