Home > Maintenance & Mods (L405) > L405 Battery Sensitivity, Beware Of Fitting Wrong Battery! |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7769 |
Wow - thanks for the heads up
6th Jan 2019 10:20am |
Charles89 Member Since: 11 Nov 2018 Location: Leicester Posts: 268 |
That is interesting, because I did the same mod. Removed the metal bracket to fit it, and I have no issue at all. I fitted a 900amp 100ah battery and it's fine. No issues at all. Are you sure something else is not causing a drain? |
6th Jan 2019 11:16am |
^ +1 There is no way installing a battery with a capacity 50Ah greater than originally specified will make the slightest difference to the car. |
6th Jan 2019 11:24am |
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 |
^ Agree. It shouldn’t make a difference. But maybe it does. Automobile magazine reported that their brand new Discovery 5 would throw up nasty error messages if they added generic, good quality Add blu instead of the (very expensive) JLR branded equivalent. Shouldn’t make a difference... |
6th Jan 2019 10:58pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16175 |
Bit of an update on this... Had LR Assist out today as my car has been getting more and more "low battery" bongs! The car was not starting after 3-4 days of inactivity... Both batteries were changed in July and it would appear the one under the spare wheel had failed! So, we put LR Assist on it today and the "battery management system" had faulted and was causing these issues! LR Assist guy ripped out the software and downloaded new and all seems to be well now...
25th Jan 2019 2:33pm |
Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409 |
wow. An LR assist guy that knew what to do ( was he actually LR? I thought they had subcontracted all of them to the AA now.)..... Apologies for my cynicism but my experience with them is not good. The last AA guy that came out to me as good as admitted he knew practically nothing about LR's.
25th Jan 2019 4:41pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1694 |
While perusing the CCF files, there are different options for the power of the main and Aux batteries.
25th Jan 2019 8:00pm |
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 |
is a supplementary battery standard on l405? |
25th Jan 2019 8:09pm |
Bloody cars!!! Been out for a 30min drive early this evening and when i turned the car off...... Yep you guessed it BONG LOW BATTERY START ENGINE!!! Grrrrr |
25th Jan 2019 10:23pm |
brian1951 Member Since: 07 Nov 2015 Location: Salop Posts: 275 |
Buy yourself a L322 |
25th Jan 2019 10:36pm |
Balloonengineer Member Since: 03 Sep 2017 Location: Kent Posts: 171 |
The battery capacity is the battery manufacturers minimum test when they come off the production line.
26th Jan 2019 11:15am |
charlie croker mk2 Member Since: 21 Jun 2017 Location: Yorkshire Posts: 174 |
If you replace ether of the batteries do you have to "code" the car in the same way that you would have to say on a BMW . |
6th Feb 2019 12:35am |
There is a BMS reset when either of the batteries are replaced, which I'm sure Craig knows about |
6th Feb 2019 10:26pm |
I was thinking of changing both batteries as a precaution , is there a way of re setting the BMS without going to a main oil changer as its 6 weeks wait and even then its impossible to talk to a engineer -- just a receptionist who makes a note on a PC LOL |
6th Feb 2019 11:00pm |
