Home > Technical (L322) > Oil leak |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4248 |
Noticed some driveway spots and a slight burning smell. Underneath the rear of the pan has some oil on it and the suspension cross bar (?)
11th Jan 2019 6:25pm |
Have you had it looked at by anyone? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
11th Jan 2019 7:00pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
First thing to check is oil cooler - the case can crack or the gasket can go.
11th Jan 2019 9:04pm |
Thanks. Oil cooler and feed pipe look ok. Checked those earlier after removing pollen filter box.
11th Jan 2019 9:19pm |
stuart_2006 Member Since: 18 Jul 2018 Location: Holsworthy, Devon Posts: 113 |
Had similar with my TD6 - garage found small split in one of the diesel plastic fuel lines, and it was diesel dripping, not oil. |
12th Jan 2019 1:13am |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1133 |
Keep an eye on your coolant tank for signs of oil? |
12th Jan 2019 9:02am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34940 |
i reckon its oil leaking from the oil cooler or turbo drain pipe and accumulating in the rear 'v' part of the engine..oil gets to much in there and drips down onto the exhaust and then the floor... |
12th Jan 2019 9:29am |
Left it with them. I couldn’t see anything around the cooler when I took the pollen filter box off last night but to be honest it’s not easy to see anything in there with the intake manifold on etc
12th Jan 2019 10:06am |
Nick591 Member Since: 04 May 2017 Location: Charfield Posts: 193 |
I have what I think is the same thing on a 2007 3.6TDV8. Oil on the bell housing left side and running down and along under left side of auto box.
12th Jan 2019 4:56pm |
cheezels Member Since: 23 Apr 2016 Location: Sunshine Coast Posts: 279 |
Keep an eye on your steering oil level.
13th Jan 2019 11:38pm |
cheezels that's really interesting. I've put UV dye in my oil and still couldn't find anything with the UV torch.
13th Jan 2019 11:44pm |
Banjo bolts opposite position two.
14th Jan 2019 12:02am |
14th Jan 2019 12:03am |
Thanks for the additional information Will report back when I have a diagnosis Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
14th Jan 2019 9:28am |
