Home > Maintenance & Mods (L322) > Washer Jets |
Are they not just frozen sir? Don't know how warm the weather has got down your neck of the woods? Seems strange they have both blocked! Remove the tubing going to your bonnet then press wash and see if you have flow first |
7th Feb 2019 11:12am |
Simon123 Member Since: 02 Jan 2018 Location: Pembrokeshire Posts: 32 |
Thanks for reply. They were working normally until last week until there was a bitof snow on bonnet. I've disconnected rubber tubing and pump is working and there is water flow.
7th Feb 2019 1:05pm |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 895 |
Each washer jet has a lip at the front (windscreen) and a squeezy tang at the rear (bonnet front).
7th Feb 2019 5:35pm |
Hi Mike,
7th Feb 2019 6:29pm |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 837 |
Having had the same problem after freezing, once removed I've disassenbled the jet unit, inside is a small spring and a small red rubber grommet that appeared to have been dislodged from its normal position and blocked any fluid flowing through to the jets.
7th Feb 2019 7:04pm |
^ Spot on.
7th Feb 2019 9:20pm |
Thanks for advice, will try the suggested remedies before I order new jets |
8th Feb 2019 10:42am |
