Home > Maintenance & Mods (L322) > Brake Caliper refurbishment
Full Fattie
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
I’ve got a 2007 SC so have 4 pot Brembo calipers on the front. They’re driving fine it seems but the paint finish is pretty much gone, if there ever was one.
I’m planning to take them off and refurbish them by blasting then powder coating. Obviously with the heat this will require removing the seals and pistons. Does anyone know which it I need to refurbish them? If it’s not too expensive then I might just do the seals regardless.
Alternatively, does anyone recommend a person/company who can do these?
Thanks
Dave
Post #505027 13th Feb 2019 3:18pm
Full Fattie
When I had a set of Brembo calipers on a previous car someone had manufactured a set of pins that could be reused. Is anything similar available for these?
Post #505042 13th Feb 2019 6:34pm
gavinn
Steering Specialists Ltd
97 Bridge Rd, Middlestown, Horbury, Wakefield WF4 5NN,
01924 267999
Great for all hydraulics
Caliper Recon and repaint
Steering Racks/Boxes
PAS Pumps
Most on a next day exchange
Ask for Jim Kenyon
Post #505088 14th Feb 2019 12:19pm
kezbo1981
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Bigg Red in Worcester
Post #505297 15th Feb 2019 10:02pm
Wet paint them will suffice... Mask up the pistons and rubbers etc... Much easier sir Thumbs Up
Post #505313 16th Feb 2019 1:24am
poworoy
England 2008 Range Rover Vogue TDV8 Galway Green
can recommend:
01924 267999
Post #676434 25th Oct 2023 5:39pm
fanders
United Kingdom 2009 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
How much do they charge for overhaul and repaint on a pair of four pot L322 Brembos? I’ve a couple that need doing.
Thanks, fanders ---------------------------------------
2009 4.2 SC Buckingham Blue
2021 Hilux 2.4
Post #676520 26th Oct 2023 8:41pm
poworoy
I only had one done- maybe a discount for a pair? approx £150, if they have to replace a bleed nipple (they put an insert in rather than just re-tapping) then extra £25 2008 Range Rover Vogue TDV8
Post #676584 27th Oct 2023 11:21am
fanders
Thanks, useful info Thumbs Up
2021 Hilux 2.4
Post #676648 27th Oct 2023 8:00pm
