Home > For Sale & Wanted > Solar powered battery conditioners
Tim in Scotland
Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland
2010 Range Rover Vogue TDV8 Stornoway Grey
Maplin is having a clear out sale and have solar powered battery conditioners on offer at £9.99 - buy on line here
http://www.maplin.co.uk/solar-powered-12v-...4qodnbyjdg
They work really well if your battery is in good nick but you won't be using the car for a couple of weeks - or in my case a couple of months at a time, even when the front screen was covered with several inches of snow this winter the charging light was still flashing indicating it was still trickle charging the battery during the day 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #54047 11th Mar 2011 11:25am
nick h
2005 Range Rover Vogue 4.4 V8 Tonga Green
thanks Tim Thumbs Up
Post #54049 11th Mar 2011 11:32am
Emperor Mong
ordered two.
Post #54052 11th Mar 2011 11:52am
ordered one Thumbs Up
Post #54067 11th Mar 2011 12:45pm
jez000
United Kingdom 2011 Range Rover Vogue SE TDV8 Bournville
Thanks Tim Thumbs Up Do you plug yours in at the lighter or direct to the battery ? 2021 P400 Silicon Silver AB
Gone 2011 Bournville TDV8 VSE
Gone 2008 Black Canadian HSE LUX
Post #54068 11th Mar 2011 12:45pm
Tim in Scotland
I put the panel onto of the instrument cluster and plug it into the ciggy lighter in the front ashtray. I had thought about putting it up on the sunroof shade but resting on the dash works fine 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes
Post #54096 11th Mar 2011 2:48pm
CyberMrT
2003 Range Rover Vogue 4.4 V8 Stornoway Grey
Fitted mine but can't tell if it's actually charging as the blue led flashes all the time.
Do all the lighter sockets/power sockets stay connected to the battery when the ignition is off?
2 sockets in the front
1 in the rear
1 in the boot
on a 2002 model L322 2002 4.4 V8 LPG
Post #54113 11th Mar 2011 5:17pm
I guess the gaps in bonnet & doors/seals are enough to allow using the battery clips then placing on dashboard with wires through door shuts?
Post #54120 11th Mar 2011 6:06pm
Emperor Mong
1 in the rear
1 in the boot
on a 2002 model
On a 2007?
My guess is that the one in the boot is always live (to, say, run a fridge).
Post #54122 11th Mar 2011 6:11pm
Easy check just use your 12v phone charger and see if its charging!
Post #54123 11th Mar 2011 6:14pm
comports
Thumbs Up Just ordered 2 also. One for the FFRR and one for my CLK (which doesn't get used much at the moment.
Thanks for the heads up..! Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #54151 11th Mar 2011 8:39pm
wackyjim
Scotland 2011 Range Rover SE TDV8 Santorini Black
Bought one for my old Ford tractor which only gets fired up every now and then!!! Laughing Laughing
Post #54154 11th Mar 2011 9:07pm
jez000
Picked one up for the first trip to the airport or when I have to leave it for a week but I checked all three lighter sockets with a mobile charger and they all power down with the ignition so it would need to be directly connected I would think ? 2021 P400 Silicon Silver AB
Post #54297 12th Mar 2011 7:50pm
Phil.
On the 2007 the 2 front sockets are not live so won't charge but the one in the boot is live and does charge. Think it was the same for my 2005 MY06.
I fitted mine with some sticky pads to the shelf by the rear side window. Fits a treat and even works well with the darker windows.
It says in the instructions to disconnect before starting to avoid potential damage to the charger. I forgot mine a couple of times in the boot and it seems to have survived.
Post #54306 12th Mar 2011 8:36pm
mercuryf1
Malaysia 2015 Range Rover SVAutobiography 5.0 SC V8 Loire Blue
If the front cig lighter is not live (when ignition off), how does this help your battery charge then Tim? '01 1.8i Freelander. Grey/ grey
'06 4.2 S/C Buckingham Blue/ Parchment
'15 5.0 S/C SVA Loire blue/ Black
Post #59533 9th Apr 2011 7:55am
