Home > Technical (L322) > Engine Management Light P0175 |
Piet Member Since: 22 Mar 2017 Location: Maasdam Posts: 199 |
Hi,
1st Apr 2019 10:28pm |
Outlet pipe of the SC. Chech the rubber connections.
2nd Apr 2019 9:55am |
Inlet manyfold
2nd Apr 2019 9:59am |
paulst Member Since: 19 Jan 2014 Location: United Kingdom Posts: 11 |
thanks for the information and images. what Im confused with, is why, given the code is running too Rich, it could be a gasket or seal and why it happened when it does.
2nd Apr 2019 12:56pm |
Yep, easy. Just pull up the top engine cover. The alu body in the middle is the SC. On both sides you see the rubbers.
2nd Apr 2019 1:13pm |
Ah great, Ill take a look when the weather clears! Thanks |
2nd Apr 2019 1:26pm |
So while we had good weather, Ive checked those seals and they seem fine. I had a check of all the pipework and everything seems fine. No Engine Light is on yet so cant read any problems.
3rd Apr 2019 4:32pm |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 |
If you have a boost leak the car will run rich, as the maf will measure air that doesn’t make it into the cylinders and add fuel for the calculated volume which obviously will be off and the car will run rich. |
3rd Apr 2019 6:54pm |
Makes sense and the possibility the problem is at the Manifolds exists by that logic, I just wondered why the EML would come on when in traffic, after about 50 miles and not while under heavy acceleration or high speeds or not straight away. |
4th Apr 2019 6:53pm |
ok, so the light has returned after 150 miles or so and its picked up rich running on Bank 2 again. It came on while sat in traffic and getting warm so presuming it is the manifold suggested thats warped slightly under the heat.
2nd May 2019 5:02pm |
anyone able to help? |
7th May 2019 3:45pm |
