Home > Maintenance & Mods (L322) > Window tints
GregP
United Kingdom 2002 Range Rover HSE Td6 Adriatic Blue
Window tints
Thinking about getting some tints on my FFRR but want to make sure I get the job done properly.
Has anyone heard anything or used this company
http://www.ultimatetinting.co.uk/index.asp
Or does anyone have any recommendations in the Devon area.
Finally what level of tint looks good on a Range Rover? Is there a standard level of factory fitted tints?
Thanks
Greg FFRR TD6 HSE
Adriatic Blue with Parchment leather.
Post #54698 14th Mar 2011 9:35pm
Pentagon are one of the best around
Post #54721 14th Mar 2011 10:55pm
JW911
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
Be careful if you get the front windows done. I was nicked a couple of weeks ago (not actually booked) for fronts which were too dark - they have the kit to test. The previous owner had them done and I've been driving around for a couple of years without a problem but I've now taken the fronts off (acetone and elbow grease) to keep it legal. See the photo below (fronts are now standard and stickers have been removed!!)
The deal is 30% or greater light transmission (up to legal threshold), £30 fine - which I avoided, despite being 30.7%!!!
20% (I think) to 30%, 3 points and a fine.
Less than 20%, a summons.
They will make you attempt to remove it on the spot. Also, it is possible that it will be added to the MoT test in the future. However, I presume if you go somewhere reputable, they'll already know the above.
 2012 4.4 TDV8 Westminster
2007 3.6 TDV8 Vogue - gone!
2003 V8 HSE (LPG) - gone!
2018 F-Pace 25t Portfolio
1974 LR Series III Lightweight FFR
2014 BMW 640i Gran Coupe
Post #54743 15th Mar 2011 12:37am
comports
IIRC the legal threshold is 30% LTV (light transmittance value) BUT... The windows are alredy tinted to a degree from the factory so you can't just chuck 27% tints on.
Worth checking it out before you spend hard earned on it. Ash
2016 SDV8 AB
Post #54755 15th Mar 2011 9:17am
