Home > Maintenance & Mods (L322) > Suspension Fault Diagnosis - Best Budget Tool |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6400 |
Non BT iiDTool. .
2nd Jul 2019 10:03pm |
Bazzer79 Member Since: 26 Apr 2016 Location: Thames Ditton, Surrey Posts: 43 |
Thanks Joe - was hoping that there would be something a bit cheaper? Not sure I even need to recalibrate the suspension? Perhaps if it was a sensor and I replaced that and cleared the fault code maybe that would solve it. In that case maybe I could use something like the iCarsoft v2.0? |
2nd Jul 2019 11:06pm |
You asked (on a budget...):
a non BT iiDTool is the best bang for buck for an L322 (imho). You can try the iCarsoft2.0 if you want...but then not sure why you asked if you have already made you mind up . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
2nd Jul 2019 11:47pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4248 |
Joe is right. You won't regret buying it. Bite the bullet and get the Bluetooth version so you can control everything off your phone app Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
3rd Jul 2019 7:22am |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3655 |
3rd Jul 2019 7:53am |
Thanks for your comments. I have no experience of using a diagnostic tool, are they simple to use? Will it allow me to recalibrate the suspension heights or does that job need something more advanced? Hi |
3rd Jul 2019 8:31am |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 510 |
I don't think the iCarSoft can calibrate the suspension? An IID Tool - either BT or non-BT can AFAIK.
3rd Jul 2019 11:14am |
Baz. They are super easy to use Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
3rd Jul 2019 11:27am |
gj88 Member Since: 10 Sep 2018 Location: West Midlands Posts: 213 |
Very easy to use, probably about as user friendly as a diagnostic system can be. Plenty of support too if you do struggle. I'd keep an eye out for a used BT one if you can stretch to it, probably £300 or so, but I really wouldn't be without mine |
3rd Jul 2019 4:00pm |
