Home > Technical > Venture cam cradle voltage
Page 3 of 3 <123
daveo
United Kingdom 2004 Range Rover 4.4 V8 Autobiography Auto Java Black
now i was told that the image uses 2.4ghz to send the video and the bluetooth gives the commands to the unit V8 facelift Range Rover Autobiography 22" wheels.
Post #62568 3rd May 2011 11:52pm
Blubberman
Wales 2005 Range Rover 4.4 V8 Vogue Auto Java Black
Another forum mentioned this , so It could be true , I don't know personally . Still trying to get my head around it all . Confused
I was wondering about using my spare camera as a permanent reversing camera , I know that when I put a 7.2 v PSU on the camera terminals when the batteries were goosed , the camera powered up and the red leds worked ok. I was wondering about mounting my spare camera down by the tow bar somewhere on a permanent voltage feed , so I can switch to it when reversing . May be useful because my reversing sensors only work when the gremlin master allows it .
Post #62572 4th May 2011 12:11am
England 2005 Range Rover Td6 HSE Auto Cairns Blue
2.4ghz is the bluetooth frequency dave...the commands are on the 435mhz frequency.. ..............................
this is handy Wink
Post #62578 4th May 2011 7:51am
stu
United Kingdom 2007 Range Rover TDV8 Vogue Auto Zambezi Silver
my cam just arrived today. brand new in the original box complete with bracket. put it in the holder, took a couple of mins then it said on display cam charging.
it is fully charged now and works a treat, i love ebay bargains and my FF is now complete as it left the factory again. Current: TDV8 Vogue Zambezi Silver
Past: TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #64547 18th May 2011 6:54pm
stu
is it ok to leave the cam in the holder all the time, or when it is charged should i take it out? Current: TDV8 Vogue Zambezi Silver
Past: TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #64823 19th May 2011 6:53pm
Scotland 2006 Range Rover Td6 SE Auto Zermatt Silver
I think it's a case of use it or lose it! I am going to run my one down once a month if I remember. I don't think it's healthy for any battery to be constantly on charge and never used. Vogue SE TD6
Post #64875 19th May 2011 8:41pm
stevenA
2002 Range Rover Td6 Vogue Auto Zermatt Silver
Just to pick up on Blubbermans post from some time back, I would like to confirm that these units are fairly straightforward to repair once the batteries are dead.
Mine was from a 2007, and so may be different from Blubbermans, but it uses 750mAh AAA Nimh batteries, not nicads. Tagged 800 mAH ones are easily found on the web, and much easier to solder. If you go down this route remember to recover the thermistor which is scotched to the old pack!. The only disadvantage with this method, is I could not reuse the fusible link that is on the original pack.
The original packs are made by GP, but I could not source anywhere.
The Venture Cam is actually held together by 3 clips, 1 on each side near the top (camera end) and 1 centrally at the bottom (plus, of course, the sealant). To open, I used a swiss army knife screwdriver head inserted 2/3 down one side and gently twisted. Once the seal is broken, slide it to the bottom until you hit the tab, and then push the tab with another slim knife to release. The other 2 will then pop out.
Although I could rejuvenate the batteries, they were gone (0 - 0.2v /cell on most). Pop the new ones in, seal and clip back togeher and it works great (and there are no visible signs of it ever having been touched.
Hope this helps!
Post #83044 21st Sep 2011 11:13pm
Page 3 of 3 <123
